FCP/Decklink Extreme crashing using DVCProHD 720p
Kevin Johnson
on Jan 20, 2011 at 3:50:00 pm
A year ago I confirmed with BMD support that FCP would crash anytime you were in a 720p DVCProHD sequence, and tried to create a text, boris text, or color frame from the viewer. The work around was to turn off external monitoring, create the text frame, and then turn it off. Once it is in the sequence the modules edit fine.
That was using 7.5.2, and I'm on 7.6. Has this been fixed in a future update? On the BMD website the current version is 7.9.4, which requires Snow Leopard which we are not running. Is there a way to get previous updates?
Kevin Johnson
Autodesk Smoke Artist
FCP Editor
Washington, DC
Shane Ross
Re: FCP/Decklink Extreme crashing using DVCProHD 720p
on Jan 20, 2011 at 7:44:18 pm
Hmmm...well, I'm running Leopard and 7.6 drivers, and I just wrapped editing of a DVCPRO HD spot. Monitoring out to a broadcast HD CRT and LCD TV. No crashing. But, I didn't try to do any text. Lemme try a couple tests and see what happens.
BMD confirmed this is an issue? Crashing with this common of a format?
Shane
Shane Ross
on Jan 20, 2011 at 8:19:17 pm
Nope...not crashing here. I do have my VIEW settings set to 720p 59.94 8-bit. Are yours?
Shane
Kevin Johnson
on Jan 26, 2011 at 8:32:13 pm
I was using the easy setup DVCProHD 720p 29.97. If I create a text (or Borris text) from the viewer, it crashes out. If I turn off external monitoring, it works fine.
BMD said the bug hadn't been addressed, and he re-flagged it. It is bug # 6497
Kevin Johnson
FCP Editor
Washington, DC
Tiago Espindola
on Feb 16, 2011 at 2:03:46 pm
Same here.
I'm running 7.9.5, and just try to click on "Controls" tab on viewer (Final Cut Pro 7.0.3) and boom! FCP shut down!!! Now im monitoring in one of my computer monitors.
My Settings for Video Playback on FCP are: "Blackmagic HD 720p 59.94 - RGB 10 Bit (1280x720).
This is the only video playback setting it is working. The others one, or i have no playback, or flickering...
I'm on a really tight schedule, so im still monitoring on computer monitor.
Any news about this problem?
Regards
Tiago Espindola
Brazil
Jörgen Gustafson
on Feb 18, 2011 at 1:15:04 pm
Same issue here. FCP crashes in seconds. If I move out the Blackmagic Codec.component (the plug) from QT plug folder and restart FCP everything is fine. I can also leave the plug and run with Cinema Display All Frames - but if I chose Blackmagic 720p (havnt yeat tryed other resolutions - will do) FCP crashes emidiately I do something..like chosing a filter etc.
The scarry thing is that this issue suddenly started yeasterday and I have not installed ANYTHING! It worked two days ago - with 720p. And it have been working like a clock for month. And suddenly....maybe it was a proapp update from Apple...maybe it was just before the issue turned up? I cant remember exactly.
Please Black Magic - look at this! I've mailed you the crash code. Take a look at it.
Jörgen Gustafson
on Feb 23, 2011 at 10:48:22 am
I've now confirmed that it's just an issue with Text-plugs. All of them. Final Cut's own and third party. Lower Third, text, Scroll, etc, - all of them. Only Text things. And it's for sure only DVCproHD 720p.
Jacek Kropinski
on Mar 12, 2011 at 7:56:23 pm
Same problem here -anyone have a solution? Blackmagic? Boris?
Jacek Kropinski
on Mar 12, 2011 at 8:45:55 pm
Here is the crash report:
Jacek Kropinski
on Mar 13, 2011 at 12:38:25 am
Process: Final Cut Pro [521]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 6.0.6 (6.0.6)
Build Info: FCPApp-905291121~12
Code Type: X86 (Native)
Parent Process: launchd [107]
PlugIn Path: /Library/QuickTime/Blackmagic Codec.component/Contents/MacOS/Blackmagic Codec
PlugIn Identifier: com.blackmagic-design.BlackmagicCodec
PlugIn Version: ??? (7.3.1)
Date/Time: 2011-03-12 16:35:44.571 -0800
OS Version: Mac OS X 10.6.6 (10J567)
Report Version: 6
Interval Since Last Report: 21884 sec
Crashes Since Last Report: 5
Per-App Interval Since Last Report: 19811 sec
Per-App Crashes Since Last Report: 5
Anonymous UUID: 36800D76-385A-4F63-8E5B-541D97D88B0D
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000082d48000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 ...agic-design.BlackmagicCodec 0x0e3e0b88 Horizontal_Upsample_RGB32_3_to_4_Vector + 206
1 ...agic-design.BlackmagicCodec 0x0e3e9808 ConversionForFrame(DeckLinkInstanceRec*, BlackmagicOutputFrameParamRec*, BlackmagicOutputFrameParamRec const*, void**, bool*, int*) + 8253
2 ...agic-design.BlackmagicCodec 0x0e3ea3d4 DrawFrameNow + 154
3 ...agic-design.BlackmagicCodec 0x0e353f89 HardwareCodecRGB_ScheduleSyncFrame + 528
4 ...agic-design.BlackmagicCodec 0x0e354219 HardwareCodecRGB_BandDecompress + 45
5 ...ple.CoreServices.CarbonCore 0x9664c054 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
6 ...agic-design.BlackmagicCodec 0x0e354672 HardwareCodecRGB_ComponentDispatch + 142
7 ...ple.CoreServices.CarbonCore 0x966447c9 CallComponentDispatch + 29
8 com.apple.QuickTime 0x94a6a143 ImageCodecBandDecompress + 43
9 com.apple.QuickTime 0x94a58274 DoBandedDecompress + 17565
10 com.apple.QuickTime 0x94a53d52 ICMAction + 1550
11 com.apple.QuickTime 0x94a527ec ICMDeviceLoop + 546
12 com.apple.QuickTime 0x94ae5ce4 PrivateDecompressImage + 1329
13 com.apple.QuickTime 0x94b173fa PrivateStdPix + 893
14 com.apple.QuickTime 0x94ae1edc DecompressImage + 552
15 com.apple.FinalCutPro 0x001aa87d SendUsingTransferCodec(KGCanvasRec*, PixMap**, OpaqueGrafPtr*, char*, OpaqueRgnHandle*) + 221
16 com.apple.FinalCutPro 0x001aad4e CopyCanvasToPixmap(KGCanvasRec*, OpaqueGrafPtr*, KGRect*, GDevice**, OpaqueRgnHandle*, unsigned char, unsigned long, unsigned long, KGTargetRec*, unsigned long long) + 1130
17 com.apple.FinalCutPro 0x001ab6dc KGTargetBlitTo(KGCanvasRec*, KGPlayerRec*, unsigned long long) + 544
18 com.apple.FinalCutPro 0x001acc90 CompressToVideo(KGPlayerRec*) + 1496
19 com.apple.FinalCutPro 0x001afb72 RenderTimer(long, long, KGDictInt*, void*) + 26
20 com.apple.FinalCutPro 0x001496e4 KGTimerInvoke(__EventLoopTimer*, void*) + 206
21 com.apple.CoreFoundation 0x998c1adb __CFRunLoopRun + 8059
22 com.apple.CoreFoundation 0x998bf464 CFRunLoopRunSpecific + 452
23 com.apple.CoreFoundation 0x998bf291 CFRunLoopRunInMode + 97
24 com.apple.HIToolbox 0x92a4e004 RunCurrentEventLoopInMode + 392
25 com.apple.HIToolbox 0x92a4ddbb ReceiveNextEventCommon + 354
26 com.apple.HIToolbox 0x92bd61a2 _AcquireNextEvent + 54
27 com.apple.HIToolbox 0x92bcbe54 RunApplicationEventLoop + 228
28 com.apple.FinalCutPro 0x0014cece KGMainEvent(void*) + 46
29 com.apple.FinalCutPro 0x002aae53 main + 59
30 com.apple.FinalCutPro 0x00003122 _start + 216
31 com.apple.FinalCutPro 0x00003049 start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x97ab2982 kevent + 10
1 libSystem.B.dylib 0x97ab309c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x97ab2559 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x97ab22fe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x97ab1d81 _pthread_wqthread + 390
5 libSystem.B.dylib 0x97ab1bc6 start_wqthread + 30
Thread 2: com.apple.CFSocket.private
0 libSystem.B.dylib 0x97aab0c6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x998ffc83 __CFSocketManager + 1091
2 libSystem.B.dylib 0x97ab985d _pthread_start + 345
3 libSystem.B.dylib 0x97ab96e2 thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x97a8c142 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x97ab9cfc _pthread_cond_wait + 1089
2 libSystem.B.dylib 0x97b0246f pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x004292ad Synchronizable::Wait() + 47
4 com.apple.FinalCutPro 0x004152e8 DisplayQueue::Run() + 702
5 com.apple.FinalCutPro 0x00453544 Thread::RunHelper(void*) + 20
6 libSystem.B.dylib 0x97ab985d _pthread_start + 345
7 libSystem.B.dylib 0x97ab96e2 thread_start + 34
Thread 4:
4 com.apple.FinalCutPro 0x004cc3e3 WorkUnitPerformer::Run() + 55
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
0 libSystem.B.dylib 0x97a8c0fa mach_msg_trap + 10
1 libSystem.B.dylib 0x97a8c867 mach_msg + 68
2 com.apple.CoreFoundation 0x998c037f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x998bf464 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x998bf291 CFRunLoopRunInMode + 97
5 ....CoreMediaIOServicesPrivate 0x0102f9ab MIO::DAL::RunLoop::OwnThread(void*) + 157
6 ....CoreMediaIOServicesPrivate 0x0103181c CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x97ab985d _pthread_start + 345
8 libSystem.B.dylib 0x97ab96e2 thread_start + 34
Thread 12:
0 libSystem.B.dylib 0x97a8c15a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x97ab9ce5 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x97ae8ac8 pthread_cond_timedwait_relative_np + 47
3 ...ple.CoreServices.CarbonCore 0x96623ecd TSWaitOnConditionTimedRelative + 242
4 ...ple.CoreServices.CarbonCore 0x96623c0b TSWaitOnSemaphoreCommon + 511
5 ...ickTimeComponents.component 0x98b66dc9 ReadSchedulerThreadEntryPoint + 4698
Thread 13:
0 libSystem.B.dylib 0x97aba0a6 __semwait_signal + 10
1 libSystem.B.dylib 0x97ab9d62 _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x97abb9f8 pthread_cond_wait$UNIX2003 + 73
3 com.apple.vImage 0x9118d50c vImageQueue_DequeueJob + 44
4 com.apple.vImage 0x9118d60c vImageWorkerThreadFunc + 124
5 libSystem.B.dylib 0x97ab985d _pthread_start + 345
6 libSystem.B.dylib 0x97ab96e2 thread_start + 34
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
4 com.apple.FinalCutPro 0x0008f6bf SyncMetaDataTask::GetNextEvent() + 81
5 com.apple.FinalCutPro 0x00090e5f SyncMetaDataTask::Run() + 39
6 com.apple.FinalCutPro 0x00453544 Thread::RunHelper(void*) + 20
Thread 21:
5 ...ple.CoreServices.CarbonCore 0x9667e732 AIOFileThread(void*) + 1127
Thread 22:
0 libSystem.B.dylib 0x97a8c14e semaphore_timedwait_trap + 10
1 ...ple.CoreServices.CarbonCore 0x96635c42 MPWaitOnSemaphore + 125
2 com.apple.DVCPROHDCodec 0x0f4c898d 0xf4c7000 + 6541
3 ...ple.CoreServices.CarbonCore 0x9660385a PrivateMPEntryPoint + 68
4 libSystem.B.dylib 0x97ab985d _pthread_start + 345
5 libSystem.B.dylib 0x97ab96e2 thread_start + 34
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x82d48010 ebx: 0x0e3e0ac8 ecx: 0x728e6fc0 edx: 0x00000001
edi: 0x00000000 esi: 0x0e3f7db0 ebp: 0xbfffd9d8 esp: 0xbfffd970
ss: 0x0000001f efl: 0x00010246 eip: 0x0e3e0b88 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x82d48000
Binary Images:
0x1000 - 0x75cfe8 com.apple.FinalCutPro 6.0.6 (6.0.6) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0xb23000 - 0xb26fe0 +KGCore ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0xb2d000 - 0xb2dff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) <18D9DCBE-A37C-3836-ABEE-09CB7AF6E71C> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0xb31000 - 0xb40ff7 com.apple.AERegistration 1.2 (72) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0xb52000 - 0xb59ff3 com.apple.AEProfiling 1.2 (18) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0xb61000 - 0xd87fe7 com.apple.prokit 6.0.2 (1177) <5E923F8B-935D-47BB-A26E-E96D6D5C24F0> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0xe8b000 - 0xebbffb com.apple.AVCVideoServices 1.0 (38) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
0xedd000 - 0xf51ffb com.apple.ProFX 1.2.3 (1.2.3) /Library/Frameworks/ProFX.framework/Versions/A/ProFX
0xf7c000 - 0xfd2fff com.apple.proapps.MIO 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x100e000 - 0x1018fee com.apple.finalcutstudio.prometadatasupport 0.5 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
0x1022000 - 0x105cffb com.apple.CoreMediaIOServicesPrivate 34.0 (1360) <8F44EB7A-C722-55D2-AF12-838553442BEE> /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x1078000 - 0x10a1ff7 com.apple.CoreMediaPrivate 20.0 (20.0) <4DFEF770-0A3C-C5B8-B264-F7F992B8B00E> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x10b4000 - 0x10e7ff3 com.apple.FWAVCPrivate 30.46 (46) <786C1EA9-AE6E-C66F-A290-8705A4F43EA8> /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
0x1171000 - 0x11b1ff7 com.apple.vmutils 4.2 (106) <92BB4844-304C-C7AB-1F9B-686537C56099> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
0x4563000 - 0x4577fc7 +com.redgiantsoftware.looks3fx 1.0 (1.0) /Library/Plug-Ins/FxPlug/Looks3.fxplug/Contents/MacOS/Looks3
0x4587000 - 0x45e9feb +com.redgiantsoftware.MBLooksRenderLib 1.0 (1.0) /Library/Frameworks/LS3Renderer.framework/Versions/A/LS3Renderer
0x47d0000 - 0x47d8ff3 com.apple.URLMount.AFPPlugin 3.2.1 (3.2.1) /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
0x47ef000 - 0x47f0fff com.apple.DVCPROHDVideoOutputCodec 1.3 (1.3) /Library/QuickTime/DVCPROHDVideoOutputCodec.component/Contents/MacOS/DVCPROHDVideoOutputCodec
0x5e5e000 - 0x5e66ff7 com.apple.proapps.mrcheckpro 1.4 (204) /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
0x5fd5000 - 0x5fd9ff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
0x5fde000 - 0x5fdffff com.apple.FinalCutPro.Plugins.Text Window 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
0x5ff6000 - 0x5ffbfff com.apple.FinalCutPro.Plugins.Cache Manager 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
0x8780000 - 0x87a4fe7 GLRendererFloat ??? (???) <1274B762-2FB9-48FE-EAFD-C459B2B4BECC> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x87d3000 - 0x87eaff7 com.apple.FinalCutPro.Plugins.AudioMixer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
0x87f9000 - 0x87fafff com.apple.FinalCutPro.Plugins.Vector Accelerator 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
0x8f00000 - 0x8f2bfe7 com.apple.FinalCutPro.Plugins.AfterEffects 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
0x8f35000 - 0x8f81ffb com.apple.audio.midi.CoreMIDI 1.7.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x8fa6000 - 0x8fbafcf com.apple.proapps.ControlSurfaceSupport 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
0x8fd0000 - 0x8fe6fff com.apple.FinalCutPro.CinemaTools 4.0.1 (4.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
0x8ff2000 - 0x8ffafff com.apple.FinalCutPro.Plugins.Effect Builder 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
0xc5b0000 - 0xc669fea com.apple.FinalCutPro.Plugins.Browser 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
0xc684000 - 0xc68fff5 com.apple.FinalCutPro.Plugins.CTHelper 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
0xc697000 - 0xc6bbffb com.apple.FinalCutPro.Plugins.EditTape 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
0xc6cb000 - 0xc6d6ff2 com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
0xc6df000 - 0xc713ff6 com.apple.FinalCutPro.Plugins.FCS Engine 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
0xc71e000 - 0xc71eff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <72FF6A91-C3EC-4634-A0FB-E1586C2404E4> /usr/lib/libmx.A.dylib
0xd00f000 - 0xd187fe7 GLEngine ??? (???) <3A6C5513-7428-2242-2892-B429C72343CB> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xd1b9000 - 0xd578feb com.apple.ATIRadeonX3000GLDriver 1.6.26 (6.2.6) <440B85D1-5BDA-EB13-2C8F-94D8D62929A8> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLDriver
0xd5a0000 - 0xd5e5feb com.apple.FinalCutPro.Plugins.EDL Export 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
0xd5fb000 - 0xd60cfff com.apple.FinalCutPro.Plugins.FilterCustomEd 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
0xd612000 - 0xd627ff3 com.apple.FinalCutPro.Plugins.FilterViewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
0xd62d000 - 0xd630ffc com.apple.FinalCutPro.Plugins.FinalTouchExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
0xd636000 - 0xd654fc3 com.apple.FinalCutPro.Plugins.Flash 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
0xd665000 - 0xd672ff3 com.apple.FinalCutPro.Plugins.GenViewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
0xd678000 - 0xd67cfff com.apple.FinalCutPro.Plugins.LayerFileReader 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
0xd681000 - 0xd6ccffb com.apple.FinalCutPro.Plugins.Media Manager 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
0xd6d9000 - 0xd6ec06e com.apple.FinalCutPro.Plugins.MolokiniSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
0xd6fa000 - 0xd70efff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
0xd71b000 - 0xd72fff3 com.apple.FinalCutPro.Plugins.Motion Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
0xd735000 - 0xd751ff7 com.apple.FinalCutPro.Plugins.Movie Analyzer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
0xd761000 - 0xd777feb com.apple.FinalCutPro.Plugins.Movie Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
0xd783000 - 0xd787fff com.apple.FinalCutPro.Plugins.NuggetExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
0xd78c000 - 0xd844fc7 com.apple.FinalCutPro.Plugins.OMF Audio Export 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
0xd863000 - 0xd86cff7 com.apple.FinalCutPro.Plugins.Perf Analyzer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
0xd871000 - 0xd887ff9 com.apple.FinalCutPro.Plugins.ProAppsIntegration 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
0xd897000 - 0xd8a4ff3 com.apple.FinalCutPro.Plugins.Pulldown Support 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
0xd8ad000 - 0xd8ecff7 com.apple.FinalCutPro.Plugins.QTM Reader 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0xd8f9000 - 0xd901fef com.apple.FinalCutPro.Plugins.QuickView 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
0xd906000 - 0xd916ff0 com.apple.FinalCutPro.Plugins.Relink Media 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
0xd91d000 - 0xd998ff4 com.apple.FinalCutPro.Plugins.Timeline Editor 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
0xd9a3000 - 0xd9aafef com.apple.FinalCutPro.Plugins.Transcoder 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
0xd9b0000 - 0xd9c2ffb com.apple.FinalCutPro.Plugins.Transition Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
0xd9c8000 - 0xd9ddff3 com.apple.FinalCutPro.Plugins.Trimming 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
0xd9e3000 - 0xd9e9ff7 com.apple.FinalCutPro.Plugins.VDUSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
0xd9ef000 - 0xda00ffb com.apple.FinalCutPro.Plugins.VideoLog 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
0xda05000 - 0xda1dfeb com.apple.FinalCutPro.Plugins.VoiceOver 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
0xda24000 - 0xda88ffb com.apple.FinalCutPro.Plugins.XML Support 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
0xe216000 - 0xe227fe7 com.apple.FCP Uncompressed 422.component 1.6.1 (1.6.1) <62C290FB-2735-60C4-CE88-7ECB0DE6EDB3> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0xe24d000 - 0xe250fef com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0xe255000 - 0xe2bafde com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0xe2da000 - 0xe320fc3 com.apple.motion.component 1.0 (1.0) <77973A13-4E79-426F-853F-2318E52A2207> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0xe326000 - 0xe32902f Motion ??? (???) /Library/Frameworks/Motion.framework/Versions/A/Motion
0xe32e000 - 0xe3faffb +com.blackmagic-design.BlackmagicCodec ??? (7.3.1) <23318E58-4EA7-5FDD-9FE8-8AA3783D32AD> /Library/QuickTime/Blackmagic Codec.component/Contents/MacOS/Blackmagic Codec
0xe437000 - 0xe44cfcf com.apple.fcp.DVOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
0xe7c3000 - 0xe7defef com.apple.AppleIntermediateCodec 1.3.2 (153) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0xe7ec000 - 0xe7f5fdf com.apple.QuartzComposer.QCMotionPatch 1.0 (1.0) <7B4D4CA7-A744-44C7-A7A6-1DEFF2C3AA75> /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/QCMotionPatch.plugin/Contents/MacOS/QCMotionPatch
0xf000000 - 0xf03afff com.apple.AppleProRes422 1.0.2 (46) /Library/QuickTime/AppleProRes422.component/Contents/MacOS/AppleProRes422
0xf086000 - 0xf46bfe3 QuickTimeH264.scalar ??? (???) <03229578-1C76-E747-A401-A8C032811360> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0xf4c7000 - 0xf50bfe7 com.apple.DVCPROHDCodec 1.4 (231) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0xf520000 - 0xf5cffe3 com.apple.AppleHDVCodec 1.6 (229) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0xf5f7000 - 0xf617ff3 com.apple.IMXCodec 1.3.1 (147) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0xf62f000 - 0xf648fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <3E236E2A-5646-8A6D-FDEE-A21C468161C0> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0xf64d000 - 0xf689fe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1756) <5723A7A8-2C99-561B-8D87-C8B0716436FA> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0xf74b000 - 0xf7a0fef com.apple.AppleProResDecoder 2.0 (223) <773F7C18-BE38-10C8-3745-0EB45E811A11> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0xf7e8000 - 0xf82fff7 com.apple.AppleShareClientCore 2.0 (2.0) <84508AC8-0173-C969-8DDC-D4E6A028954A> /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
0xf846000 - 0xf87dfe7 com.apple.motion.MotionBundle 3.0.2 (3.0.2) /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
0xf893000 - 0xf89fff7 com.apple.PluginManager 1.7.5 (50) /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
0xf8f9000 - 0xf8fafff com.apple.Helium 2.1.2 (2.1.2) /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
0xfa00000 - 0xfa4efe3 com.apple.soundtrackpro.integration 2.0.2 () <3A8F3A1F-839F-4D69-98BB-14B5570902AB> /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
0xfcea000 - 0xfcfafff com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (1.2.3) /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
0xfd05000 - 0xfd15fff com.apple.fxplugframework 1.2.3 (1.2.3) /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
0xfd7c000 - 0xfd81fe3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
0xfd88000 - 0xfdbcfcf com.apple.Helium.HeliumRender 1.0.2 (1.0.2) /System/Library/PrivateFrameworks/Helium.framework/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
0xfe24000 - 0xfe5efef +ProMath ??? (???) <92BC79AA-6524-43AA-AB63-994E4D88F004> /Users/media1/Library/Frameworks/ProMath.framework/Versions/A/ProMath
0xfe92000 - 0xfedeff3 +Bloodhound ??? (???) <2AFB0ADB-33BE-4A24-AA3F-4C6F6B057CB8> /Users/media1/Library/Frameworks/Bloodhound.framework/Versions/A/Bloodhound
0xff19000 - 0xff24fff com.apple.motion.Text 3.0.2 (3.0.2) <416454D0-E1C8-4517-A28D-656E6F14D26D> /Applications/Motion.app/Contents/PlugIns/Text.ozp/Contents/MacOS/Text
0xff37000 - 0xff3cffb com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
0xff44000 - 0xff46ffb com.apple.Helium.HCache 2.1.2 (2.1.2) /System/Library/PrivateFrameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
0xff4c000 - 0xff50ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <6A211097-72ED-1461-4050-72C9101D79E4> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0xff55000 - 0xff5bffb com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <404165FF-1BA0-706B-F48A-10AC997162B1> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0xff60000 - 0xff6cff7 com.apple.DVCPROHDVideoOutput 1.3 (1.3) /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
0xff75000 - 0xff8cfef +ThirdPartyPlugins ??? (???) <9F285487-7336-439B-8EF2-169F820B1745> /Users/media1/Library/Frameworks/ThirdPartyPlugins.framework/Versions/A/ThirdPartyPlugins
0xffb8000 - 0xffc3ffe com.apple.fcp.TundraOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
0xffcf000 - 0xffd4ff7 com.apple.DesktopVideoOut 1.2.4 (1.2.4) /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
0xffd9000 - 0xffe3ff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0xffed000 - 0xffeeffc com.apple.compressor.stomp 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Compressor
0xfff2000 - 0xfff3ffc com.apple.qmaster.swamp 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
0x10000000 - 0x1005efef com.apple.proapps.AudioMixEngine 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x30200000 - 0x30218fdf +com.redgiantsoftware.MisFire.Basic.Scratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Basic Scratches.bundle/Contents/MacOS/MisFire Basic Scratches
0x30db2000 - 0x30dd0fd0 +com.redgiantsoftware.MisFire.Deep.Scratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Deep Scratches.bundle/Contents/MacOS/MisFire Deep Scratches
0x3197e000 - 0x31996fc4 +com.redgiantsoftware.MisFire.Displace ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Displacement.bundle/Contents/MacOS/MisFire Displacement
0x32530000 - 0x3254bfca +com.redgiantsoftware.MisFire.Dust ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Dust.bundle/Contents/MacOS/MisFire Dust
0x330f7000 - 0x3310eff4 +com.redgiantsoftware.MisFire.Fading ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Fading.bundle/Contents/MacOS/MisFire Fading
0x33ca7000 - 0x33cbefd8 +com.redgiantsoftware.MisFire.Flicker ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Flicker.bundle/Contents/MacOS/MisFire Flicker
0x34857000 - 0x3486efdc +com.redgiantsoftware.MisFire.Funk ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Funk.bundle/Contents/MacOS/MisFire Funk
0x35407000 - 0x35422fc0 +com.redgiantsoftware.MisFire.Gate.Weave ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Gate Weave.bundle/Contents/MacOS/MisFire Gate Weave
0x35fce000 - 0x35fedfc8 +com.redgiantsoftware.MisFire.Grain ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Grain.bundle/Contents/MacOS/MisFire Grain
0x36b9a000 - 0x36bb5fc8 +com.redgiantsoftware.MisFire.MicroScratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire MicroScratches.bundle/Contents/MacOS/MisFire MicroScratches
0x37761000 - 0x37778fd4 +com.redgiantsoftware.MisFire.Post.Contrast ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Post Contrast.bundle/Contents/MacOS/MisFire Post Contrast
0x38311000 - 0x3832cfd6 +com.redgiantsoftware.MisFire.Splotches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Splotches.bundle/Contents/MacOS/MisFire Splotches
0x38ed8000 - 0x38eeffd4 +com.redgiantsoftware.MisFire.Vignette ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Vignette.bundle/Contents/MacOS/MisFire Vignette
0x3a44d000 - 0x3a47afd7 +com.redgiantsoftware.MisFire ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire.bundle/Contents/MacOS/MisFire
0x3b085000 - 0x3b0c6fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x3b0cd000 - 0x3b0d8fff com.apple.compressor.MediaServerAPI 3.0.5 (3.0.5) /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
0x3b0e5000 - 0x3b0f1fff com.apple.compressor.StompUtil 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
0x3b200000 - 0x3b24afec com.apple.DVCPROHDMuxer 1.3 (1.3) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x3b268000 - 0x3b2a6fff com.apple.compressor.ImageProcessing 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
0x3b2dd000 - 0x3b2e4fff com.apple.compressor.FilterUI 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
0x3b400000 - 0x3b532fe0 com.apple.motion.filters 3.0.2 (3.0.2) /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
0x3b593000 - 0x3b5bcfe3 com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x3b5cd000 - 0x3b5d7ffc com.apple.qmaster.SwampUtil 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
0x3bfeb000 - 0x3c720fdf +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
0x3d15f000 - 0x3d891fc7 +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
0x3e2cf000 - 0x3e9fffef +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
0x3f43c000 - 0x3f48afdf com.apple.compressor.StompUI 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
0x3f4b8000 - 0x3f4c1fff com.apple.qmaster.SwampService 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
0x3f4d1000 - 0x3f4dffff com.apple.qmaster.Status 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
0x3f600000 - 0x3fd36ff7 +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
0x40781000 - 0x4078cfff com.apple.qmaster.RequestProcessing 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
0x407a1000 - 0x407b2ff7 com.apple.qmaster.ServiceControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
0x407cc000 - 0x407d8ffe com.apple.qmaster.ClusterManager 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
0x40a00000 - 0x40a40fef com.apple.qmaster.SwampCore 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
0x40a83000 - 0x40aa1fff com.apple.qmaster.SwampUI 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
0x40abd000 - 0x40ac9fff com.apple.qmaster.SwampExecutor 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
0x40c00000 - 0x415a2fcf com.apple.ozone.framework 3.0.2 (3.0.2) /Applications/Motion.app/Contents/Frameworks/Ozone.framework/Ozone
0x41b8d000 - 0x41c38fce +ProCore ??? (???) /Users/media1/Library/Frameworks/ProCore.framework/Versions/A/ProCore
0x41c84000 - 0x41d01fc3 +ProMedia ??? (???) /Users/media1/Library/Frameworks/ProMedia.framework/Versions/A/ProMedia
0x41d83000 - 0x41ddffeb +ProGraphics ??? (???) <61F87C63-1750-4359-8352-2E1859903EAE> /Users/media1/Library/Frameworks/ProGraphics.framework/Versions/A/ProGraphics
0x41ecd000 - 0x42036fe7 +Lithium ??? (???) <5AB1A031-2828-44A5-AE3F-50F0493AF478> /Users/media1/Library/Frameworks/Lithium.framework/Versions/A/Lithium
0x420d7000 - 0x4228cff7 com.apple.motion.TextFramework 3.0.2 (3.0.2) <5724E41C-ED67-4788-AB20-41AFC54E7E7B> /Applications/Motion.app/Contents/Frameworks/TextFramework.framework/TextFramework
0x4232f000 - 0x424b1ff3 com.apple.motion.Behaviors 3.0.2 (3.0.2) /Applications/Motion.app/Contents/PlugIns/Behaviors.ozp/Contents/MacOS/Behaviors
0x42567000 - 0x426ebff3 com.apple.motion.Particles 3.0.2 (3.0.2) <50A60444-2B17-4D84-A881-AA441CBF558A> /Applications/Motion.app/Contents/PlugIns/Particles.ozp/Contents/MacOS/Particles
0x42754000 - 0x42791fff com.apple.qmaster.SwampTypes 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
0x427e6000 - 0x427ebfff com.apple.finalcutpro.dvcprohdfrcplugin 1.2.0 (16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
0x42d85000 - 0x42e6bd9b com.apple.AECore 3.0.5 (3.0.5) /Library/Frameworks/AECore.framework/Versions/A/AECore
0x42f00000 - 0x42f45fff com.apple.qmaster.do 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
0x43800000 - 0x438e5fe3 com.apple.compressor.StompTypes 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
0x43981000 - 0x43aeaffb com.apple.compressor.transcoding 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
0x43bfb000 - 0x43c41fff com.apple.qmaster.ContentControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
0x43c7c000 - 0x43d3dfff com.apple.qmaster.JobControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
0x43de5000 - 0x43e9afe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) /usr/lib/libcrypto.0.9.7.dylib
0x575ec000 - 0x577dfff7 +net.telestream.wmv.import 2.1.0.33 (2.1.0.33) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x57f00000 - 0x57f2bfea com.apple.fcp.FCPAudioUnits 0.0.8 (1.1) /Applications/Final Cut Pro.app/Contents/Resources/FCPAudioUnits.bundle/Contents/MacOS/FCPAudioUnits
0x58e00000 - 0x58e7afe7 com.apple.AppleVAH264HW.component 2.0 (1.0) <203359C6-AB8D-89A3-5927-4C8D3DE9F060> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0x70000000 - 0x700cbff3 com.apple.audio.units.Components 1.6.3 (1.6.3) <5DA35A22-1B05-6BD3-985A-26A7A2CD6289> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x7d20f000 - 0x7d3edff3 com.apple.audio.codecs.Components 2.0.2 (2.0.2) <8B43D24A-277D-5F42-8741-FC8736C44162> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <749D24EE-54BD-D74B-D305-C13F5E6C95D8> /usr/lib/dyld
0x90003000 - 0x900cdfef com.apple.CoreServices.OSServices 357 (357) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x900d0000 - 0x900d2ff7 com.apple.securityhi 4.0 (36638) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x90111000 - 0x90117ff7 libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x90118000 - 0x9015eff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x90167000 - 0x9019ffe7 libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <242954AD-3BE1-29E8-E2E0-08063201F105> /usr/lib/libcurl.4.dylib
0x901a0000 - 0x9024dfe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) /usr/lib/libobjc.A.dylib
0x90256000 - 0x90327fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <631392F6-6E50-278C-70FF-7969E35C498D> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x90328000 - 0x90334ff7 libkxld.dylib ??? (???) <9D8378E0-1C58-EED8-EA00-F4515B8BE7A3> /usr/lib/system/libkxld.dylib
0x90335000 - 0x90373ff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x90374000 - 0x903bbffb com.apple.CoreMediaIOServices 134.0 (1160) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x903bc000 - 0x903fbff7 com.apple.ImageCaptureCore 1.0.3 (1.0.3) <7E02D104-F31C-CF72-71B4-DA5DF7B48337> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x903fc000 - 0x90831ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <4D2F47EF-BD32-1E3C-6A0A-438896ADE2BE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90832000 - 0x90832ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x90833000 - 0x90837ff7 libGFXShared.dylib ??? (???) <9E14BE2F-C863-40E9-41A6-1BE9045663A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x90838000 - 0x9085effb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9085f000 - 0x908b0ff7 com.apple.HIServices 1.8.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x908b1000 - 0x909a5ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x909a6000 - 0x909b7ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x909b8000 - 0x90a05feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <27F3FF53-F818-9836-2101-3E963FE0C0E0> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x90c1b000 - 0x90c2bff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
0x90c2c000 - 0x90c2cff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
0x90c2d000 - 0x90c3afe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) <5B68F977-F7E1-F419-F900-A5B34A30FE05> /usr/lib/libbz2.1.0.dylib
0x90c3b000 - 0x90d3cfe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
0x90d3d000 - 0x90d3dff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90d3e000 - 0x90db5ff3 com.apple.backup.framework 1.2.2 (1.2.2) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x90db6000 - 0x90decfff libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x90e18000 - 0x90f9afe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
0x90f9b000 - 0x90fa0ff7 com.apple.OpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x90fef000 - 0x9100ffe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) /usr/lib/libresolv.9.dylib
0x91010000 - 0x91060ff7 com.apple.framework.familycontrols 2.0.2 (2020) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x91061000 - 0x910c5fff com.apple.htmlrendering 72 (1.1.4) <0D22B190-513B-7FF6-39FC-9D336285DE08> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x910c6000 - 0x911a3ff7 com.apple.vImage 4.0 (4.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x911a4000 - 0x911e6ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x911e7000 - 0x91261fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x91262000 - 0x91364fef com.apple.MeshKitIO 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x91542000 - 0x915f2ff3 com.apple.ColorSync 4.6.3 (4.6.3) <0354B408-665F-8B3F-87FF-64E6322276F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x915f3000 - 0x9161bff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <12FBE8CB-CC8E-FE8A-7362-C852625C5AAF> /usr/lib/libxslt.1.dylib
0x9161c000 - 0x9165efe7 com.apple.MediaKit 10.3 (485) /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x9165f000 - 0x91662fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x91668000 - 0x91698ff7 com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x91699000 - 0x9169dff7 IOSurface ??? (???) <235E7E3D-B6E5-0AAA-C41A-7AC1F54A7EBF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9169e000 - 0x916a5ff3 com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x916f4000 - 0x91713fe3 libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <7236668D-1D61-0ED8-9F22-35DBBF661175> /usr/lib/libexpat.1.dylib
0x9172d000 - 0x91a98ff7 com.apple.QuartzCore 1.6.3 (227.34) <0B59EAF1-4892-C5CE-4A67-66EBD383359E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x91a99000 - 0x92288557 com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x922d3000 - 0x9230afe7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
0x92389000 - 0x92393ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92403000 - 0x92447ff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x92448000 - 0x92623ff3 libType1Scaler.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x92624000 - 0x9262cff7 com.apple.DisplayServicesFW 2.3.0 (283) <305F9514-2404-5CF7-AFB4-00BB4D2EA69E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x9262d000 - 0x92670ff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9268a000 - 0x928fdfe7 com.apple.Foundation 6.6.4 (751.42) <65F16BF4-D106-F2F5-53F3-5BFBC2FCE608> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92a0e000 - 0x92a18fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92a19000 - 0x92d3dfef com.apple.HIToolbox 1.6.4 (???) <4699C8BB-DE74-C530-564B-D131F74C9B54> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92d3e000 - 0x92db9fff com.apple.AppleVAFramework 4.10.12 (4.10.12) <0B523224-8EE3-988D-04BE-D608953CC977> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x92dba000 - 0x92fc1feb com.apple.AddressBook.framework 5.0.3 (875) <759B660B-00F6-F08C-37CD-69468C774B5E> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x932bc000 - 0x932cafe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x932ce000 - 0x9330bff7 com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9330c000 - 0x93330ff7 libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x93350000 - 0x93368ff7 com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x933aa000 - 0x93423ff7 com.apple.PDFKit 2.5.1 (2.5.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x93424000 - 0x93464ff3 com.apple.securityinterface 4.0.1 (40418) <26D84A83-F5B9-93CF-71BB-0712698181EE> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x93470000 - 0x936d3fff com.apple.security 6.1.1 (37594) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x936d4000 - 0x9378aff7 libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9378b000 - 0x9378dff7 libRadiance.dylib ??? (???) <68BF4654-B74A-C843-759F-7FC62385F251> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9378e000 - 0x937fdff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93820000 - 0x93834fe7 libbsm.0.dylib ??? (???) /usr/lib/libbsm.0.dylib
0x93835000 - 0x93963fe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93964000 - 0x9396dff7 com.apple.DiskArbitration 2.3.1 (2.3.1) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9396e000 - 0x93d84ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <9D89FCB3-24C9-8FCF-DB49-27B184AC3222> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x93db8000 - 0x93dbbffb com.apple.help 1.3.1 (41) <6A5AD406-9D8E-5BAC-51E1-E09AB9A6D159> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x93dbc000 - 0x93df9ff7 com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x93dfa000 - 0x93e24ff7 com.apple.shortcut 1.1 (1.1) <08A1868D-FEF4-8FB3-D814-79385DCBEC7D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x93e2a000 - 0x93ed8ff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x93ed9000 - 0x93f43fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x93ff9000 - 0x9403dfe7 com.apple.Metadata 10.6.3 (507.15) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9403e000 - 0x9411cfef com.apple.QuickTimeMPEG4.component 7.6.6 (1756) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x9411d000 - 0x94138ff7 libPng.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94139000 - 0x94143ff7 com.apple.HelpData 2.0.4 (34) <001A7163-C977-C30F-1B4B-4F5647F72E96> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x94144000 - 0x94158ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <9F5CE4F7-D05C-8C14-4B76-E43D07A8A680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x94159000 - 0x9415aff7 com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9415b000 - 0x94a3bff7 com.apple.AppKit 6.6.7 (1038.35) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94a46000 - 0x94d3ffef com.apple.QuickTime 7.6.6 (1756) <3C041DD9-A5DB-60CA-8418-E58A78C9468E> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94d40000 - 0x94d40ff7 com.apple.Carbon 150 (152) <734BDB59-8B13-54FA-0653-AA8623DF9846> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x94d41000 - 0x94e70fe3 com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /S
Jörgen Gustafson
on Mar 13, 2011 at 9:46:23 pm
Strange that Blackmagic havn't fixed this. They usually very fast to fix issues and they often update drives. This must me a hard nut to crack for them. I've been forced to work with projects in 1080 to avoid this bug.
Jörgen Gustafson
on Mar 22, 2011 at 11:58:19 am
Update 7.9.6 did NOT fix the problem. Com'on Blackmagic! Fix it!
Jörgen Gustafson
on Apr 26, 2011 at 8:04:47 am
I havn't hard tested yet...but it seems like the 8.0 update of drivers fixed this issue. :-)
