Video Capture Problems
Saul Wade
on Jan 16, 2011 at 2:22:08 am
Hello,
I have a Blackmagic Design Decklink Extreme card and Final Cut Pro. When capturing video the end result of that capture is video that runs faster and the length of the video is shorten by 65%.
I am not sure if is the card or the software that is causing this problem.
Any suggestion how to fix this? Thanks.
Shane Ross
Re: Video Capture Problems
on Jan 16, 2011 at 5:42:20 am
Do the frame rates match what you have on tape? Are you trying to capture 29.97 to 23.98, for example?
Shane
