To install only Blackmagic codec.
alejandro Castan
on Jan 10, 2011 at 5:06:53 pm
Hello all
Sorry but I would need to install only the Blackmagic Decklink Extreme HD for Windows into one PC without Adobe Premiere and Decklink Video Capture card, for it, Could anybody help me with this topic
Thanks in advance
Best Regards
Alejandro Castan
Shane Ross
Re: To install only Blackmagic codec.
on Jan 10, 2011 at 8:07:07 pm
You don't need a capture card to install the drivers. But as far as I know, there are no "Decklink codecs." Just settings for existing codecs for the various NLEs. Apple has ProRes, so Decklink installs drivers that allow the card to see those ProREs files. But it doesn't install ProRes.
What Decklink Codec are you talking about?
Shane
alejandro Castan
on Jan 12, 2011 at 7:09:02 pm
Hello Shane,
First, thanks for your answer.
Well, I have a Decklink Extreme 2 HD Card.
On the other hand, I fixed the problem because I installed all the Blackmagic software and I can work without the decklink card installed.
Thanks for your help.
Best Regards
Alejandro
Joshua Helling
on Jan 13, 2011 at 7:22:09 pm
Excellent, that's correct. You can install our drivers without a card and that will allow working with the project settings and codecs.
We used to have a separate codec pack, but we discontinued it. It is much simpler to maintain one installer package than two.
Always make sure that you have the same version of the drivers installed on both the systems.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
