DeckLink HD Extreme 3D up converting
Javier Sanchez
on Jan 6, 2011 at 1:16:52 am
Hello we have a URSA telecine SD wich is being captured by the new DeckLink HD Extreme 3D plus, what i want to know is, if i select the blowup option to HD what is the card doing with the SD signal?
Searching for a complex answer but i didn't found any...
Regards
Shane Ross
Re: DeckLink HD Extreme 3D up converting
on Jan 6, 2011 at 2:53:39 am
The hardware is scaling the footage. Are you looking for the engineering specs on what EXACTLY it is doing? I don't think they are out there.
Shane
Javier Sanchez
on Jan 6, 2011 at 3:06:11 am
Yes in fact i'm looking for the engineering specs to explain my clients thats it's quite a good option.
Regards
Shane Ross
on Jan 6, 2011 at 3:56:47 am
Will your clients understand the specifications if you told them? My producer glazes over when I talk about what I need to do to get codecs to match. I just say "hardware is better...it just is."
Shane
Javier Sanchez
on Jan 6, 2011 at 12:53:29 pm
Yes sure but you know there is always a client who know everythink, Thats why. Last time i client cause me problems because i didn't give him R3d archives colored in 4k i had to explain him that he didn't need it for Tv comercial thats why i gave him hd 10bit uncompress. But he discuss with me about the color information....
So thats why i need to know, cause there is always a client who want to be clever than you...
