how to set the used reference
Hung Han
on Dec 20, 2010 at 6:44:32 pm
Hi
I wish someone could help us to set the input reference used by the application "DecklinkKey.exe" (SDK 7.9)...
We are using a color bar as input signal and reference input, when we select the "Key Control" to "Off" the output's reference is
the same to the signal that is on "Ref-in" but when we select the "Key Control" to "Internal" the output's reference is
different, it's seen that it is locked by another reference... Because the horizontal position reference is
different from the input reference signal and it's seen the signal is locked at a "random" position because it is never at the same
position
We are using the 7.9 drivers, Windows XP and we have a Decklink Studio 2. This is happening at SDI and Analog signal
Could you help us to find where could we set at the code to use the same reference input (preferencialy
the one used by "Blackmagic Control Panel") or give us any suggestion?
Regards,
Hung
Hung Han
Re: how to set the used reference
on Dec 21, 2010 at 10:10:19 am
I'm sorry, the horizontal reference position is OK. The VERTICAL reference position is changing
Regards
Hung
Hung Han
on Dec 28, 2010 at 4:07:55 pm
Hi
Could anyone help us?
Regards,
Hung
Hung Han
on Jan 3, 2011 at 4:09:08 pm
Hi
Is it possible to select which reference to use using a decklink?
Regards,
Hung
Hung Han
on Jan 31, 2011 at 4:26:26 pm
Hi
No one knows?
Regards,
Hung
