install Decklink, which slot, MacPro 2010
toby Heslop
on Dec 9, 2010 at 10:40:07 pm
Is there a preferred slot that a Decklink Extreme 2 card should be installed in a macpro 2010 model?
the top slot has 'RAID' printed on the motherboard.
Does it matter which slot the card is seated in?
Kristian Lam
Re: install Decklink, which slot, MacPro 2010
on Dec 10, 2010 at 3:04:12 am
Hi
You can use the 3rd slot.
regards
Kristian Lam
Blackmagic Design
Kristian Lam
on Dec 10, 2010 at 3:04:27 am
Hi
regards
Kristian Lam
Blackmagic Design
toby Heslop
on Dec 10, 2010 at 3:25:42 am
3rd slot from the top or 3rd slot from the bottom?
Joshua Helling
on Dec 13, 2010 at 10:00:02 pm
Hehe,
Good point, I hate the way those are labeled. Slot 3 or 4 will work great. Those are the top two slots. The MacPro's label from the bottom up. This means Slot 1 is on the bottom (typically your graphics card) and slot 4 is on the top.
FWIW, when I build rigs in my lab or for use at trade show, I put the Decklink in Slot 4 and the HBA (for the drive controller) in slot 3 and it works a treat every time.
Hope that helps.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
toby Heslop
on Dec 14, 2010 at 8:55:21 am
thanks Josh
