Decklink HD extreme3D and FCP 7
Chris Cea
on Dec 3, 2010 at 6:55:57 pm
Hi all, I am a new to the world of Blackmagic design products and was wondering if within the Final Cut Pro 7 Capture settings I should be seeing NTSC Capture settings for Standard ProRes, ProRes LT and ProRes Proxy? I was expecting to have these as options. Was I wrong in expecting that?
What's even more strange to me is that I do have an NTSC capture setting for ProRes HQ. But that's the only ProRes setting I have for SD capturing.
I am on a 2x2.66Ghz 6 Core running 10.6.5
Any ideas???
Thanks for any help guys
Chris
Kristian Lam
Re: Decklink HD extreme3D and FCP 7
on Dec 4, 2010 at 6:08:03 am
Hi Chris,
We don't provide commonly used settings or else the list of Easy Setups will be so long everyone will have a hard time looking for the right one!
However, you can easily make your own based on the ProRes HQ preset. Else give our support guys a call and I'm sure they will be able to send you a preset you can install.
regards
Kristian Lam
Blackmagic Design
Chris Cea
on Dec 6, 2010 at 1:36:18 pm
Hi Kristian, Thanks for responding. I did exactly what you suggested and it worked great.
Thanks again
Chris
