Sdi Out not working
Teguh Pria Setiawan
Sdi Out not working
on Dec 1, 2010 at 3:35:13 am
Hallo,
Even i played video with decklink card to Digital/Analog Monitor, my video only succed show at Analog Video but not succes show at Digital Monitor.
Can you tell my, how the way if i want show my video at Digital Monitor?
Must I Do ReConfigure BlackMagic Design Software at COntrol Panel?
Thank's
I have a Monitor Digital there are two Input Select, Analog and Digital.
Now I am making Newsticker Software with Sdk Medialooks [multimedia_sdk_3.3.5.4 or declink_multimedia_sdk_3.3.0.3] and Decklink Card Extreme, I succes show my Newsticker output to Analog Monitor use Y-Out but I can't Show my output to Digital Monitor use Sdi Out.
Can you give me a Solution in order to i can show my output to Digital Monitor?
Thank's
Kristian Lam
re: Sdi Out not working
on Dec 3, 2010 at 12:25:59 am
All outputs are active on the card so it should work.
Can you provide more details?
1) Model of the monitor
2) Model of your DeckLink card
regards
Kristian Lam
Blackmagic Design
