HDLINK Pro DVI & HDLINK Display Port and new Apple 27" LED Monitor
Michael Kammes
on Nov 29, 2010 at 10:02:40 pm
Phone support was unable to provide an answer, so it was suggested I post on the 'cow.
Short Question: Can a HDLINK Pro 3D Display Port or HDLINK Pro DVI push a new 27" Apple Cinema Display (with a Display port to DVI Adapter) full screen, and at resolutions ABOVE 1920 x 1200?
Long Question: Consider the facility workflow:
CPU out via BM DVI Extender
to
BM Video Hub (HD-SDI)
to
HDLINK Pro DVI
to
Monitor.
I confirmed with Engineering at Blackmagic 6 months ago that the DVI Extender – whether in video mode for video gear (1080i) or extender mode (for use with HDLINK Pro (max 1920 x 1200)) cannot fill a 30” monitor. No way around it while using this config.
(BTW, If this is wrong, I would LOVE to hear about it, we've been using older Apple 30" displays with only the center of the screen being used for months)
I'm afraid that an Apple 27" may have the same problem. However, if I replace the HDLINK Pro DVIss with the HDLINK Pro 3D Display Port, would that aid in any way?
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.com
Kristian Lam
Re: HDLINK Pro DVI & HDLINK Display Port and new Apple 27" LED Monitor
on Dec 3, 2010 at 12:31:34 am
Hi Michael,
Currently, the 27" Apple Cinema display will not work and we're looking into it.
regards
Kristian Lam
Blackmagic Design
Kip Gynn
on Jan 31, 2011 at 4:18:19 am
We are considering purchase of an HDLink ProDVI.
I wish to feed the HDLink Pro DVI with the 2K SD signal coming from the RedOne camera.
Will the Apple Cinema Display model # A1081 show a full screen image when connected to the HDLink ProDVI female DVI port??
Michael Kammes
on Jan 31, 2011 at 2:46:38 pm
In our facility, this will not work. The image is centered and will not fill the screen.
The resolution maxes out at 1920 x 1200.
~Michael
Hear me pontificate: Speaking Schedule .
Kip Gynn
on Jan 31, 2011 at 10:12:45 pm
the apple cinema display I have is 1680 x 1050 60hz, so it probably wont work?
Michael Kammes
on Jan 31, 2011 at 10:20:34 pm
In my experience, anything BELOW 1920 x 1200 is OK. Anything ABOVE 1920 x 1200 will be problematic because the HDLINK PRO is NOT dual link, which is required for ACDs with resolutions higher than 1920 x 1200.
I'm hoping this changes soon!
~MIchael
