Decklinck Extreme 3D - How can I output a Frame-Packing Signal
Stefan Bauer
on Nov 12, 2010 at 1:25:25 pm
I am trying to output a Frame-Packing Signal from the BM Media Express Player to my 50" Plasma 3DTV via HDMI 1.4 but i can't get it to work.
The only options in the BM settings for 3D Output are Side-by-Side, Top-Bottom, Interleaved, Left and Right. But there is nothing about Frame-Packing, where each's eye resolution keeps the full HD resolution.
By the way, I use two separate 1808p24 streams which I combined to a 3D stream in the software.
Quirin
George Bellias
Re: Decklinck Extreme 3D - How can I output a Frame-Packing Signal
on Nov 12, 2010 at 8:49:42 pm
What a coincidence, I just called in the exact same question to Tech Support. The rep did not know and is checking on it for me. I will let you what I find out.
George Bellias
Jade Productions
Allan Barnwell
on Nov 12, 2010 at 8:58:02 pm
I'm having the same problem.
The promotional blurb on the website says something about the card being intelligent enough to switch automatically, but I don't see that happening.
Allan Barnwell
on Nov 12, 2010 at 9:46:36 pm
Are both of you using certified 1.4 cable? I'm not but my other 1.4 devices are working with the one I have. That may be why the card isn't auto recognizing the display.
Stefan Bauer
on Nov 12, 2010 at 9:56:01 pm
Me not, but as far as I know HDMI 1.4 doesn't require new cables . The confusing thing for me is the fact, that there's just no option for the Frame-Packing mode in the BM software.
Allan Barnwell
on Nov 12, 2010 at 10:26:00 pm
The 1.4 cables are capable of carrying more data for 3D. I've got one coming in the next hour and I'll let you know if it fixes my problem.
Allan Barnwell
on Nov 12, 2010 at 11:59:05 pm
So BM tech support said that at this time the current firmware does not support frame packing on capture or playback.
Stefan Bauer
on Nov 15, 2010 at 7:49:02 am
ok but does anyone know how to get a hdmi display feed with a frame packing signal? Are the any other cards/converters? As far as I know the BM Extreme is the only card havinga hdmi 1.4a output
Morten Schmidt
on Apr 2, 2011 at 2:20:48 pm
u need to go into the BM control panel and put the 3D feature to on
I done playback with framepacking output to my Acer monitor
MacPro 4.1 16GB Ram, 4x1TB drive BD-burner IOHD 2x30" Apple Display and lots of stuff..
Apple Rocks !
