this computer does not have any serial ports matched the specified by the current preset. You will need to set the port"
John Reis
on Nov 11, 2010 at 7:58:46 pm
Just installed an intensity Pro card in my mac. Have not gotten any signal out to my monitor. Figured I d try the Black Magic NTSC 8 bit Easy Set up, then a matching sequence of Bars and tone.
I got this message after switching to NTSC 8 bit Easy Set Up. Dont know what it means.
Kristian Lam
Re: this computer does not have any serial ports matched the specified by the current preset. You will need to set the port"
on Nov 14, 2010 at 1:53:44 pm
Sounds like you could be using the DeckLInk drivers instead of the Intensity drivers. Since Intensity and Intensity Pro cards do not have RS422 ports on them, the easy setups we supply will not check for serial ports, but the ones we supply for the DeckLink cards do so.
You can either adjust the easy setups so that deck control is set to not controllable, or use the Intensity drivers instead.
regards
Kristian Lam
Blackmagic Design
