Decklink Extreme HD-SDI and HDMI simultaneously
Neil Sadwelkar
on Nov 6, 2010 at 10:05:43 am
With the new Decklink HD Extreme 3D can I get video (and embedded audio) out over HD-SDI and simultaneously over HDMI as well?
Further, can I route the embedded audio (6-8 tracks) through HDMI so that I could use a professional HD-SDI monitor for video and a home theatre with HDMI input for the 6-track audio?
Should be possible as the manual for Decklink says (pg 46)...
"This example shows DeckLink HD Extreme 3D connected to a Sony HDCAM SR series digital deck in 4:2:2 HD mode for capture and playback to the HD-SDI deck. The HDMI, spare SDI and component analog outputs can be used for local monitoring of 4:2:2 HD video."
Anyone connect it this way?
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Pablo Nóbrega
Re: Decklink Extreme HD-SDI and HDMI simultaneously
on May 2, 2011 at 1:19:03 pm
I really would like to know the same!! I thank you if you have the answer... Saludos.
