HP Dreamcolor + hdlink 3d & Decklink extreme 3d = Cailbration?
Sean Kapleton
on Nov 2, 2010 at 2:44:18 pm
Hello
I am about to pull the trigger on a home 12-core setup for color correction (color & Davinci) and want to use a Dreamcolor with an Extreme 3d & hdlink 3d but if this is true and a proper adapter does not exist for display port to hdmi 1.4a then we have a problem!
I am curious in comparison to the AJA HDP2 if I am using a Dreamcolor is that hdmi 1.4a or only 1.3? Is there any difference between the e2 converters?
Also does anyone know what settings i should have in the hdlink 3d utility for use with the Dreamcolor (rec. 709)?
sean
Manuel López
Re: HP Dreamcolor + hdlink 3d & Decklink extreme 3d = Cailbration?
on Nov 2, 2010 at 10:15:16 pm
You can connect directly the Dreamcolor to the HDLink3D adapter via DisplayPort.
http://digitalfrozen.com/
Sean Kapleton
on Nov 3, 2010 at 5:24:34 am
what is the quality differences?
Sean Kapleton
on Nov 3, 2010 at 5:53:28 am
specifically is it the same as hdmi 1.4a or 1.3, how does it perform in comparison to the HDP2, what setting should I have when using with a Dreamcolor for grading and what exact display port size connection are we talking because it seems larger?
Manuel López
on Nov 3, 2010 at 6:56:43 pm
Better read excelent Allan Tepper articles in Provideocoalition:
http://provideocoalition.com/index.php/atepper/story/dreamcolor_from_hp_an_...
Sean Kapleton
on Nov 5, 2010 at 3:50:47 pm
Hey Manual
so i read the article in thep ast but read it again as well as all of the links in the article itself but I am still curious what if any difference there is between HDMI 1.3/4 and display port.
I ask because I am debating whether to get the HDLINK 3d display port OR the AJA HDP2 for use with the HP Dreamcolor - this is for color correction purposes and having the highest possible quality (10bit) is very important!
thanks
sean
Manuel López
on Nov 10, 2010 at 2:51:44 pm
I use for color grading Decklink Extreme 3D, HDlink Displayport and Eizo CG243W, via displayport.
I hope this help you, and read this also: http://forums.creativecow.net/thread/124/874776#874776
