Decklink & Red Rocket
Nikolai Pigarev
on Nov 1, 2010 at 6:41:49 pm
I had it working with the AJA card but made a switch because of the RESOLVE.
I am trying to monitor RGB 444 signal out of REDROCKET it goes out via dual link SDI that goes into the dual link sdi from the decklink and i was hoping it would come out of HDMI or 3G SDI but no luck so far.
Is it possible? Are the inputs and outputs always active?
P.S. I know HDMI has no RGB but i have added a hdlink in the mix. And a direct dual link red rocket to hdlink works now just wanted to work via decklink so as not to switch cables.
Margus Voll
Re: Decklink & Red Rocket
on Nov 2, 2010 at 2:40:57 pm
HI.
Asfar as i know DL card gives out stuff when you have supported software running ?
RR wil just be as a hardware speedup for resolve with r3d.
I'm not really sure how you would like to use DL ?
Margus
http://iconstudios.eu
Nikolai Pigarev
on Nov 2, 2010 at 2:59:20 pm
The idea is like that. RR gives out RGB only via dual link sdi (or the breakout box that i dont have) I have a dreamcolor monitor tht can take in HDMI 10BIT but it need to be RGB so plan is use RR to DL to HL to DREAMCOLOR
Margus Voll
on Nov 3, 2010 at 3:26:50 pm
I'm not sure that DL gives pass trough when no supported software is running.
I would go with separate rgb to something converter maybe ?
Margus
