Log and capture problems using FCP7, HDW2000 deck and Multibridge Pro.
Brenda Delv
on Oct 20, 2010 at 11:16:08 pm
Hi.
I have a movie that was shoot with the Sony F900, I whant to transfer the footage to my computer for editing.
I am using Multibridge pro 2, Mac Pro Two 2.4GHz Quad-Core Intel Xeon “Westmere” processors and Sony HDW-2000 deck.
I have everything connected, I can see the image on a monitor connected to the deck and I can manipulate the deck from my computer, but I CAN NOT SEE THE IMAGE ON THE LOG AND CAPTURE WINDOW FROM FCP7 and therefore I can not capture anything.
I connect the deck to Multibridge via SDI, and also using a 9-pin plug, as explained in the Multibridge manual.
My setups is as follows.
BLACKMAGIC SETUP:
SET AOTPUT: SDI & HDMI & Composite & component
SET INPUT: SDI VIDEO & AES/EBU AUDIO.
FINAL CUT SETUP:
Easy setup: FORMAT: All formar. RATE: All rate. USE: Blackmagic HDTV 1080p 24 Apple Pro-Res (HQ)
Please I need help I try a thousand ways and I can not get it. Sorry for my English, my first language is Spanish.
Thank You.
Brenda.
Kristian Lam
Re: Log and capture problems using FCP7, HDW2000 deck and Multibridge Pro.
on Oct 22, 2010 at 4:04:23 am
Is it really 24p or 23.98p? If it is 23.98, then choose the 1080p23.98 easy setup in FCP.
regards
Kristian Lam
Blackmagic Design
Brenda Delv
on Oct 24, 2010 at 6:26:59 pm
The deck can read the tape in 24 but when trying to capture the image appears for a second then disappears, comes and goes constantly. The same in 23.98 easy setup.
