passing/editing VANC with Decklink Studio
Adam Szabo
on Oct 19, 2010 at 7:09:49 am
I started a project with Decklink Studio. My final goal is to insert some VANC data into SDI stream.
First tests showed that if I use Composite input and output with Media Express, TXT information (PAL signal, lines 20-22) is not going trough against all my efforts. I specified the lines I want to preserve in Control Panel, but nothing comes out. I tried to convert the Composite signal to SDI with Broadcast Converter, but the result was the same.
Is there a way to pass this information? What am I missing?
If I develop my own application, will it work on all the interfaces or just SDI?
If I loop through SDI data, can I edit it on the fly with only one card?
Thanks in advance.
Adam Szabo
Re: passing/editing VANC with Decklink Studio
on Oct 23, 2010 at 9:58:06 am
Sorry. My bad. Dumm questions. I figured it out.
