DecklinkPlayback sample is flicking
Hung Han
on Oct 13, 2010 at 8:34:07 pm
Do you know why the DecklinkPlayback sample is flicking? I tried with two "HD extreme 3" and both are flicking. The video flick once around 10 seconds (it shows a blue screen quickly and then back to normal).
I'm using :
* The DeckLink 7.9 drivers
* DecklinkPlayback.exe from "Blackmagic DeckLink SDK 7.9"
* HD Extreme 3
If it is not SW problem, what kind of problems could it be?
Regards,
Hung
Hung Han
Re: DecklinkPlayback sample is flicking
on Oct 14, 2010 at 1:08:36 pm
Hi
More details about the problem:
* I'm playing a SD video
* I'm using the SDI output "8 Y OUT"
* The flick happens when i blend a image, it could be the "Blackmagic Design NTSC.bmp" file
* After around 30 seconds it is showing a blue screen quickly and then back to normal
Could someone knows what could it be?
Regards,
Hung
Hung Han
on Oct 15, 2010 at 7:26:03 pm
Hi
Problem solved, i was using the REF-IN and the signal was not tri-level
