Media Express to playout
thiru narayanan
on Oct 10, 2010 at 1:21:59 pm
Hello
We run a cable channel. We need to play out some clips to our switcher or play out system. Can I play out using the scheduler in media express. This is for live broadcast of certain clips. I have a CG system downstream that too with decklink SDI for titling (live). Will there be any sync problems??
Also I have to take the output from the CG system to a long distance about 6 km (we are PAL SD). If I use decklink fiber optic can I run the optic fiber direct from the CG system to the necessary location or do i need some optical tranceiver or something??
