Sync Generator for RGBHV
Kurro Gonzalez
on Sep 7, 2010 at 5:19:29 pm
Hi everybody.
Probably I will say something stupid, but I've recently seen a monitor with RGBHV connections. I must say I don't know much about HV sync signals. What I'd like to do is to send RGB signal from my Multibridge Pro 2 to this monitor. But I need to get some reference. Is there any way to convert a reference signal produced on a BlackMagic Sync Generator onto H and V signals?
http://www.tyrisfilms.com
Bob Zelin
Re: Sync Generator for RGBHV
on Sep 8, 2010 at 12:02:26 am
modern monitors (even 10 year old monitors) use Y Pb Pr component signals, and a few use R G B, with SYNC ON GREEN. Modern monitors (even 10 year old monitors) don't use H and V sync - they use sync on green. Even if the jacks are there, they will probably use sync on green (this is called composite sync, where the H+V sync signals are composited, or superimposed on the Green channel, or the Y channel).
If in fact you have a 20 year old monitor that demands using external horizontal and vertical sync - WHO CARES - it's too old, you can't use it, throw it out. It's not "cool" to get this working, with the low cost of modern products today. I don't care if it's free. Throw it out.
Your multibridge pro will have sync on the Green or Y channel. You have to do nothing to make this work.
Bob Zelin
Margus Voll
on Sep 8, 2010 at 8:10:07 am
Yes use modern stuff. With multibridge which i also have it is really no brainer and simple as that.
Just put in small sync generator and be worry free :)
I even do not remember that i have a generator.
Margus
http://iconstudios.eu
