Intensity Pro/ CS5 & Multi-cam
Randy Johnson
on Aug 27, 2010 at 7:13:08 pm
I am starting to use CS5. I convert my footage over to DVCpro HD to edit. Everything seems to work fine except when I try and use multi-cam. I open the multi-cam window it looks fine until I hit play then it only shows one source streatched across the window and then many times it crashes. Anyone else with this issue?
Randy Johnson
Rando1968@comcast.net
