Pocket Ultrascope and Express34 USB 3.0
Marc Colemont
on Aug 11, 2010 at 1:57:27 am
Did anyone tried to connect the Pocket Ultrascope with these new Express34 cards on a Macbook Pro running Windows7 bootcamp (as Mac OSX does not support USB 3.0 express43) yet?
I won't need 3G, mostly 720P or 1080i viewing.
Kristian Lam
Re: Pocket Ultrascope and Express34 USB 3.0
on Aug 12, 2010 at 1:37:52 am
Hi Marc,
It's not going to work because the ExpressCard 1.0 interface (2.5 Gb/s)does not provide enough bandwidth requested by the Pocket UltraScope.
regards
Kristian Lam
Blackmagic Design
Marc Colemont
on Aug 12, 2010 at 6:41:30 am
Ok thanks... bummer actually.
Does it completely not work, or does it give dropped frames in the software when using it?
Also when you connect non-3G sources like SD or 720P?
Then the bandwidth should be fine. As my MXO2 does transfer 1,45GHz 720P and 1080i sources through the Expresscard34.
Thanks for your help.
Danny Hays
on Aug 12, 2010 at 9:01:14 pm
I was wondering the same about the Shuttle. My laptop PCI express slot doesn't have the bandwidth to support the Shuttle, so it won't let me install the software, even if I only wanted to use the lower bandwidth settings, SD or MJpeg, so most likely your in the same boat. I had to build an I7 with an X58 chipset motherboard with
USB 3.
