DeckLink HD Extreme 3D Questions (Kristian Lam)
Aaron Pulicano
on Aug 5, 2010 at 10:08:35 am
Hello,
I my name is Aaron and I have been trying to reach Mr. Kristian Lam for a few weeks for an update. We were in discussion about the DeckLink HD Extreme 3D features for HDMI capture using 8-Bir RGB 4:4:4 and 3D stereoscopic.
His last post:
http://forums.creativecow.net/readpost/124/874350
My last post (view for PS3 3D PDF data-sheet):
http://forums.creativecow.net/readpost/124/874448
I have money set aside for the 3D Extreme, but need to hear back from him first.
If anyone knows Kristian or another member of BlackMagic could reply it would be appreciated.
Aaron
Joshua Helling
Re: DeckLink HD Extreme 3D Questions (Kristian Lam)
on Aug 5, 2010 at 10:28:17 pm
There has been no update on that particular issue. At this time I do not believe it has been put into the development cycle. So essentially there is no new headway on supporting 8bit 4:4:4.
The current HD Extreme 3D is physically not capable of frame packed HDMI capture/playback and is not something we can update on the card.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
Aaron Pulicano
on Aug 15, 2010 at 11:28:40 pm
Thank you for the reply. That is fine, maybe the next generation DeckLink HD Extreme 3D will support framepacked 3D v.i HDMI. And it sounds like it will be awhile before any news or updates come about adding RGB 8bit 4:4:4 capture v.i HDMI for the DeckLink HD Extreme 3D (if any). I mean could you give me a best guess if HDMI RGB 8bit 4:4:4 will be ever be added to the current DeckLink HD Extreme 3D? Is like less then 25% chance or even less?
If that is the case, it might be best to go with an Intensity Shuttle for now (even though it lacks RGB capture). However, could you tell me if the below card will work with the Intensity Shuttle and also be able to support 1080p60 capture when that is added to the Intensity Shuttle v.i firmware update?
Two main things I was looking for is RGB 8-Bit 4:4:4 in 480p60, 720p60, and 1080p60
http://www.newegg.com/Product/Product.aspx?Item=N82E16813995004
External Connectors:
2 x USB 3.0 ports.
Interface:
PCI Express x4 interface
