Loading Iridas 3D LUT's via SDK?
Kyle Granger
on Jul 23, 2010 at 11:21:00 am
Hi All,
This is my first post. I'm pretty new with the DeckLink SDK. I am integrating the DeckLink 3D Extreme with the SI-2K cameras, 2d and 3d, for SDI out (monitoring, and possibly live broadcast).
In our capture software (SiliconDVR) we use Iridas LOOK files for 3D LUTs. The GPU handles the rendering; MOV files use Cineform codec, which also supports .look files.
I see in the DeckLink manual how to manually load a look (in cube format, I believe). But I don't see that exposed as part of the SDK.
Is is not yet possible to load an Iridas look/cube file via the DeckLink SDK?
Thank you!
Kyle Granger
