Decklink SDI
Alan Hunter
Decklink SDI
on Jul 13, 2010 at 7:14:57 pm
I've just finished building two new systems, both are Intel-based using Windows 7 Professional as an OS. One of the systems has a Decklink SDI PCI-e card in it and every time I shut it down and then re-start the computer, the Decklink card is not recognized either in the bios, nor on boot=up of Windows. If I move the card from one slot to another I can get the bios to recognize the card, but I don't want to have to do this each and every time I start the system. I have swapped out several pieces of hardware that I think might be in conflict, like replacing a PNY GeForce GTS250 video card with an older Nvidia FX-1400 and pulling a PCI-X SATARaid card. Could it be an issue with the Decklink card itself or could it be software based?
System Specs.
-Intel BOXDP55WG LGA 1156 Intel P55 ATX Intel Motherboard
-Intel i5-750
-PNY GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 Video Card
the aboved was swapped with a Quadro FX-1400
-G.SKILL Trident 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
-WD 2500ks 250gig HD for OS
-Liteon SATA DVD
-3 SATA Quad Bay Ice Boxes 1TB each
Software
-OS Windows 7 Professional
-Latest Decklink Drivers
-Latetst Nvidia Drivers
-CS4 Premire Pro
-After Effects 7.0 Professional
