SDI to Audio
Peter Bell
SDI to Audio
on Jul 12, 2010 at 12:46:18 am
My sdi to audio mini convertor doesnt seem to like sd sdi deembedding.
I am using a pdw700 camera as its input. I the unit is fed hdsdi it works great but with sdsdi input i am getting clicking noises every couple of seconds.
Joshua Helling
Re: SDI to Audio
on Jul 13, 2010 at 8:16:09 pm
Are you de-embedding to AES or analog? Or does it not matter? Also are you outputting PAL or NTSC. I can try to have my guys check this in our lab.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
Peter Bell
Re: SDI to Audio
on Jul 13, 2010 at 11:40:55 pm
I am deembedding to analog pal system
ian clark
Re: SDI to Analogo Audio on Mini Converter
on Nov 3, 2010 at 10:42:39 am
Does anyone know what the diagram on the back of the mini converter box means? I have SDI to Analog box but no idea what to do with the mini switches. I look at that diagram and my brain starts to switch off. It's like there are three diagrams in one. For example I look at the first bit no. 8 Analog Aud/AESEBU Aud. So what can I do with that? There are extension illustrations on the 2-4 Audio set up but what on earth should I be flicking up and down to achieve exactly what? There is no documentation to explain and it would be nice to make some sense of this to get the most of the box....
