Blackmagic codecs Vegas 9e
Larry Brewer
on Jun 30, 2010 at 3:03:06 pm
First, my appreciation for the work put into Media Express 2.1. Blackmagic listened to my concerns and acted. I couldn't be more pleased.
I am using Sony Vegas 9e. When I render SD or HD AVI with Blackmagic codecs, I get an unintended black level increase. Probably 7.5% NTSC setup. This is a problem since some of my clips already have 7.5% setup.
The exception is when rendering using motion jpeg Blackmagic codec there is no increase in setup.
Is there a setting I'm not aware of?
I've added a post with this same question in the Sony Vegas forum and so far have gotten no takers.
Thanks for any suggestions.
Larry Brewer
HD Extreme
PC Win 7
Intel quad core cpu
Intel Motherboard 12 gig ram
Kristian Lam
Re: Blackmagic codecs Vegas 9e
on Jul 1, 2010 at 11:28:29 am
Hi Larry,
We will get our QA team to check this out and get back to you.
regards
Kristian Lam
Blackmagic Design
Larry Brewer
on Jul 1, 2010 at 4:00:18 pm
Kristian
Seeing how the Media Express will only play clips that were either captured by a Blackmagic card (HD Extreme in my case) or clips that are rendered using Blackmagic codecs, the idea of having a codec that can be used to transparently convert an mov, mpeg2, or wmv file to avi Blackmagic is important.
Most of my clips I import to Media Express are avi files. I use Sony Vegas 9e to convert them to avi 4:2:2 Blackmagic so they will be compatible with Media Express 2.1. This is where I see the black level increase. In broadcasting we called this the pedestal, or setup.
I wouldn't expect the hue to change or the color saturation, so why should I accept a black level change? It messes up the contrast and makes everything look washed out.
Again, thank you for passing this on and I look forward to a fix or at least a work around.
Kristian Lam
on Jul 2, 2010 at 12:02:36 am
Hi Larry,
Are you converting to 8-bit or 10-bit?/ Looks like a gamma issue so I'll get the guys to check it out.
regards
Kristian Lam
Blackmagic Design
Larry Brewer
on Jul 2, 2010 at 3:06:45 am
It doesn't matter if it's 8 bit or 10 bit, or SD or HD. Any codec except motion jpeg. And I don't think it's a gamma issue. 7% to 10% setup is added to the video as it is rendered. I have to assume it has to do with NTSC 7.5% setup. I think I need to send "before and after" screen caps of my WFM scope.
Thanks again for your attention to this matter.
Larry Brewer
George Sey
on Jul 3, 2010 at 5:06:39 pm
Hello Kris
Does intensity work with Vegas
