Still have the same problem even after upgrading to HD Extreme 3D
Yasser Amin
on Jun 26, 2010 at 10:07:54 pm
Hello
I post a problem in Jun 3 about cutting in the sound in premiere CS5 put I did not find any response from support guys
http://forums.creativecow.net/readpost/124/873967
I thought the problem was caused by my old Decklink Extreme PCI, so I decided to build a new system with Decklink HD Extreme 3D, The surprise was I had paid 1000$ for the same problem but with new card
I will explain this problem again and I hope to find help
after I upgrade to CS5 I get a problem cut in the sound for two seconds then go back again while playback timeline, I test several wave sound files 48 KHz 16 bit stereo and get the same problem which was working will with CS4, there is no level in Premiere Audio Meter Panel when cutting in the sound happen, I monitor my sound throw XLR card output to speaker
this problem not from the system or from the card but I think it's from the driver because I got this problem in two different systems
I work in an animated series for children, all the Video clips is video only without audio 720*576 avi uncompressed 8 bit yuv blackmagic codec exported from premiere, all audio files is 48 KHz 16 bit stereo
system: Windows 7 64 Bit, ADOBE PRODUCTION PREMIUM
Cards: Decklink Extreme PCI & Decklink HD Extreme 3D
Driver: V7.6.4
Project: SDI 8 Bit 720X576
regards
Kristian Lam
Re: Still have the same problem even after upgrading to HD Extreme 3D
on Jun 29, 2010 at 11:00:37 am
What about generating tone from within premiere pro? Does the tone cut out?
regards
Kristian Lam
Blackmagic Design
Yasser Amin
on Jun 29, 2010 at 1:57:53 pm
Hello Kristian
I test tone generated from premiere and there is no cut out in sound, but must note that is tone has a constant audio level not like a recorded voice which contains a variable volume level
below In the attached photo you will find in the top picture of the original project, and at the bottom picture of the test project with tone
this issue only happened when I upgrade to CS5 and driver V7.6.4 In 3 different computers with 3 decklink Extreme PCI Cards and 1 Decklink HD Extreme 3D in multiply project with different audio files
hope I get a solution
regards
Kaspar Ko
on Jun 29, 2010 at 6:39:45 pm
Hello,
Can you tell me how the file was generated? Was it given to you? Did you capture it with our Media Express v2? Premiere? Exported from another application?
To me it sounds like it may be the method in which that particular video was encoded. Try this, do a New Project with a Blackmagic setting of PAL 8bit. Capture a clip. Then immediately drop that clip into the timeline and play it back. Does the same issue happen there? The reason I ask is because you said the files have been exported prior to being placed on the timeline in your previous post. Also if you were to use Media Express v2, capture a file and play that file back, does the same dropouts occur? And does it also do the drop out from your existing file? If it's a Blackmagic uncompressed AVI, Media Express v2 shouldn't have any problems playing out the file.
And also can you tell me a little more about your machine spec, audio card, motherboard, RAID, etc?
Regards,
Kaspar Ko
Blackmagic Design
Yasser Amin
on Jun 29, 2010 at 9:59:43 pm
Hello
the clips is generated from 3DS Max, After Effect and Animo as series TGA 720*676 24 bit, I import each series to
premiere and export every clip as AVI Blackmagic uncompressed 8 bit, I am not capture any clip, the sound file is
WAV file 48 KHz 16 bit stereo contains a dialogue, that is all clips I used, this clips I used it before with CS4 and Was
working well, and the old project created with CS4 has the same issue with CS5 but with CS4 it's working without
any problem "with old driver"
with premiere preset using Motherboard sound card there is no issue
have 3 computer
2* Boxx Workstation 8300 with Blackmagic Extreme PCI in PCI-X slot + MediaVault 4210 Raid
1 * Asus P45 P5Q Deluxe with Blackmagic HD Extreme 3D "Temporary Computer until get new Boxx workstation
8500"
Clean install Windows 7 64Bit + Adobe Creative Suite Premium CS5 not demo version
PS: I was a beta tester to Blackmagic driver and I can confirm that issue related to 7.6.4 driver not to other software or hardware
regards
Yasser Amin
on Jun 30, 2010 at 2:36:01 pm
Hello
I found strange something don't notice it before
in Premiere-> Preference-> Audio output Mapping
there is 2 Blackmagic Map output
1- BlackMagic Audio
2- BlackMagic Audio (CS5)
and if I choose BlackMagic Audio (CS5)and return to Preference window I found that it return once again to BlackMagic Audio
below is picture
I want to know what is the deference between them ?
regards
Yasser Amin
on Jul 5, 2010 at 9:25:17 pm
Hello
any feed back from support ??
Yasser Amin
on Aug 4, 2010 at 2:09:58 pm
Hello
even after new driver V7.7.3 still the problem exist
any help please
regards
thong dv
on Sep 20, 2010 at 2:38:21 am
I have observed this forum
same trouble
and now when there are 7.9 drivers
I have not heard anything in the BMD project
I do not understand this problem belongs to adobe or BMD?
Yasser Amin
on May 20, 2011 at 3:17:16 pm
Happy birthday
It's been a year now and I still had the same problem
I upgrade my system to all new Decklink driver
I upgrade adobe premiere to last CS5.0.3
and still get drop out in sound, no sync issue just randomly drop out in sound
Hardware: Asus P5Q Deluxe
system: Windows 7 SP1 64 Bit, ADOBE PRODUCTION PREMIUM CS5
Driver: V7.9.5
Yasser Amin
is this forum for Blackmagic?
on May 31, 2011 at 9:45:55 am
where is technical support ? Why this neglect in responding to this problem ?
