Media Express Settings
George Sey
on Jun 11, 2010 at 10:32:20 pm
I used Media Express today for the first time and was not impressed with the settings. Also there was not much information there too. I used Motion jpeg and the quality was bad. I used 8bit and 1hr was 78gb with great quality but big space usage.
What is the best setting to use. In Premiere the rates are not bad.
Kristian Lam
Re: Media Express Settings
on Jun 16, 2010 at 1:17:56 pm
Hi George,
What do you mean by settings? Can you be more specific?
If you're referring to the quality settings for MJPEG, then it's currently locked down and is not user adjustable.
However, the quality is good. There is the offchance that the wrong encoder is being called. Do you have any other "codec packs" installed on your system?
regards
Kristian Lam
Blackmagic Design
George Sey
on Jun 19, 2010 at 6:49:59 pm
I am talking about the quality of the settting as they are different from Premiere's. I settled for the 8bit which is super quality. Only that I need more space as an hour is 77gb compared to Premiere's 13gb.
Thanks Kris.
George
Andreina Marcano
on Aug 25, 2010 at 12:54:27 pm
Hello,
What codecs are used with media express?
