Acquiring HD
Dan Asselin
Acquiring HD
on Jun 5, 2010 at 4:09:13 pm
Hi;
I have been asked to capture an HD signal from a live event and quickly turn it into a DVD. I use Adobe Encore and will be situated in a mobile production truck.
Do you think that any of the Blackmagic products would work for me in this regard?
Thanks............Dan
Larry Brewer
Re: Acquiring HD
on Jun 6, 2010 at 8:04:42 pm
If you are capturing HD and intend to burn a standard def DVD you will, of course, have to downconvert the file to SD. You will also need to produce an .m2v video file and an .ac3 audio file for DVD burning.
This you should be able to accomplish within your Adobe Encore.
If you are intent on burning a HD disk, you will need Blu-Ray authoring software
Ever considered Sony Vegas? You could do worse....
Steve Wargo
Re: Acquiring HD
on Jun 10, 2010 at 10:45:25 pm
While you're t it, could you please turn some water into wine. Another guy did that so I know it can be done.
I think there's a JVC DVD recorder that might do that. The DVD, not the wine thing.
Steve Wargo
Tempe, Arizona
It's a dry heat!
Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD .
Ask me how to Market Yourself using Send Out Cards
Steve Wargo
Re: Acquiring HD
on Jun 10, 2010 at 10:48:09 pm
pro.jvc.com/pro/attributes/DVD/brochure/srhd1250_1500.pdf
Steve Wargo
Tempe, Arizona
It's a dry heat!
2-Sony EX-1 HD .
