Media Express "not supported on this architecture"
Julius Miller
on May 29, 2010 at 5:09:36 am
Hi There
What are the minimum specs for Media Express? When i try to install/run it says it is not supported on this architecture??? Does it require a Mac Pro??? I cant seem to find specs on it... I am running it with a Multibridge Pro which is working fine on m y system...
Julius
Brian Louis
Re: Media Express "not supported on this architecture"
on May 30, 2010 at 11:11:16 am
[Julius Miller] "it is not supported on this architecture???"
What's the architecture you are running on?
Julius Miller
on May 30, 2010 at 11:20:27 am
Hi There
I am running a G5 - Dual 2.3 GHz; 8.5GB Ram, OSX 10.5.8. with a Multibridge connected via PCI express card. Final Cut Studio 2.
Hope this is enough info...
I though originally that it was because my monitor did not support 1920x1200 resolution but i then downloaded a previous version of Media Express (V2.03) that allows lower resolutions but got the same error...
I assume it means you need a Mac Pro but it does not say anywhere in the documentation that this is required???
