Decklink SDI CS5 can't capture only sound
Iliya Gitlin
on May 28, 2010 at 12:02:24 pm
Win 7 x64
decklink SDI PCI-Exp driver 7.64
CS5
i can't capture only sound - without video
captured file is empty, but file size is correct.
if capture video+audio all ok
Fred Jodry
Re: Decklink SDI CS5 can't capture only sound
on May 28, 2010 at 1:34:56 pm
Try capturing either blackburst video or timecode on screen video next to your sound then use the feature in your editor software that lets you dub audio editing without dubbing or mixing wrong video. It`s the most regular of the different ways.
Iliya Gitlin
on May 29, 2010 at 6:48:24 am
it is not very convenient because audio dubbing can not be used in a batch mode.
I have DigiBeta tape video with audio recorded, but i need capture only sound from this tape in bath capture - 10-20 small parts must be capture in separate clips. Older version Premier CS3-4 and older version decklink driver success capture audio without video.
