After Upgrade to CS5 - Reinstall Intensity Pro?
Christopher Ahrensback
on May 26, 2010 at 11:46:19 am
PP CS5 should be arriving any day now. Do I need to reinstall the Intensity Pro software/drivers after upgrading CS3 to CS5?
Just wondering if the Blackmagic presets will still be there.
Margus Voll
Re: After Upgrade to CS5 - Reinstall Intensity Pro?
on May 26, 2010 at 12:13:29 pm
Hi.
Usually always you instal BM drivers after Premiere.
Margus
http://iconstudios.eu
Kristian Lam
on May 26, 2010 at 1:50:13 pm
In fact, we have a new update just out today with more presets!
Either way you should always reinstall if you upgrade your Adobe suite as the drivers need the presence of Adobe's preset folders to install the presets.
regards
Kristian Lam
Blackmagic Design
on May 26, 2010 at 2:11:38 pm
As I suspected!
Thanks Kristian :)
Jack Donnelly
on May 30, 2010 at 2:11:06 pm
I've just upgraded to Prod Premium CS5 from CS4 on my Vista 64 bit system and then installed the new 3.6.4 Intensity Pro driver. PP does not see the Intensity Pro at all now and I can't get playback from the preview window or the timeline. Any suggestions?
Jack Donnelly
Ball Ground Video Productions
Jack Donnelly
on May 30, 2010 at 11:06:28 pm
Removed and reinstalled driver - now presets are showing up correctly and PP and Intensity Pro are talking.
Jack Donnelly
Elton Rossi
Re: After upgrading to CS5 - Reinstall Intensity Pro?
on Dec 2, 2010 at 5:23:21 pm
Also tou com lock my problem CS5
