Can I Join Two Studio Videohub's Together?
Jack Jones
on May 22, 2010 at 3:24:44 pm
I'm in the process of designing our new machine room and the cabling infrastructure to go with it.
I started up a design based around a 32 channel patch hub, which is pretty much all we currently need, plus and extra 4 spare slots. I'm planning on sending everything, including the GUI's over SDI into the suites utilising DVI-to-SDI and back convertors.
In summary. Is it possible to buy two BMD Studio Videohub's and connect them so they're both completely workable?
Example; 'Suite 1 on Board 1 takes Deck 1 on Board 2' whist simultaneously 'Suite 2 on Board 1 takes Monitor 1 on Board 2'
Hope that's sort of clear!
Jack
Jack Jones
Re: Can I Join Two Studio Videohub's Together?
on May 22, 2010 at 3:50:26 pm
Alternatively... Is it possible to do the following;
On Channel 1 is Edit 1 and Monitor 1
On Channel 2 is Edit 2 and Monitor 2
Is it possible to do Monitor 2 takes Edit 1*????
*Possibly by doing Mon 2 takes SDI Out from Channel 1
Any help would be nice, I'm planning on giving BMD a call early next week for some numbers etc.
Jack
Kristian Lam
on May 24, 2010 at 12:19:13 pm
If you are thinking of doubling up the routes, then you'll really need 4 units to get the full matrix, however, if you're thinking of sending signals from one router to another rough some creative routing, that's still possible.
regards
Kristian Lam
Blackmagic Design
