Requirements for RGB/3D capture?
Aaron Pulicano
on May 20, 2010 at 11:48:04 am
Does anyone know the requirements for RGB/3D capture with the DeckLink HD Extreme 3D? For example, in all cases for RGB 24/30 (8bit/10bit) is either Dual Link HD-SDI or Dual Link 3G-SDI required for RGB 24/30 capture up to 1080p60 (or will single link 3G-SDI also work)? Additionally, I don't see SMPTE 344M listed as part of the card's SDI Standard, does that mean 480p capture is not possible v.i SDI? As for Stereoscopic 3D, dual link HD-SDI or dual link 3g-sdi is required? Thanks
