Cannot Capture Analog With Intensity Pro
Jeremy Gadd
on May 16, 2010 at 8:24:11 am
Having finally got IP to work I now find that I am having problems capturing anything analog. I am using the break out cable and have got the correct leads and inputs. What happens is that when I try to capture (using either BM's media express or Adobe Premiere 4.2.1) it captures a few frames then goes black. Captures a few more and then goes black again. In real time it just looks like a flicker.
I have even tried using different leads to check if it is a cabling problem.
Windows 7 64 bit
Intel dual core 2.8ghz
Asus P5QPL-VM
4gb ram
Intel G41 integrated GPU
http://www.asounddesign.eu - UK Based Video Editing, Multimedia and Web Designer
Kristian Lam
Re: Cannot Capture Analog With Intensity Pro
on May 17, 2010 at 1:35:56 pm
What kind of analog? Is it composite or component? What is the source of the video?
regards
Kristian Lam
Blackmagic Design
