CS5 problems
Brett Kelly
CS5 problems
on May 7, 2010 at 2:27:13 pm
Hello, having some issues on Windows 7 64 bit Premiere Pro CS5. I can not get any playback on the program windows. Source plays fine but anything on the timeline just refuses to play. DV works fine. Using latest 7.6.2 drivers...
Ian Lewis
Re: CS5 problems
on May 7, 2010 at 4:46:29 pm
Me, too. Just unwrapped and installed and been playng for an hour or so. Thought it might be some setting I hadn't found, but maybe not...
Kristian Lam
Re: CS5 problems
on May 8, 2010 at 3:41:32 am
Hi Brett,
Can you list out more details about your hardware? What graphics card is installed in your PC?
What is the format of video you're playing? Is it a Quicktime .MOV? Is it uncompressed 10-bit AVI?
Also, which Blackmagic Design product is installed in your system?
regards
Kristian Lam
Blackmagic Design
Ian Lewis
Re: CS5 problems
on May 8, 2010 at 11:19:13 am
I began again. It works as expected for me (playing both source and program monitor through the BM output) but you have to select the BM player in the "Player" options in general preferences.
Derrick van Niekerk
Re: CS5 problems
on May 13, 2010 at 11:15:43 am
You probably have to disable the stop on dropped framed option in Premiere.
