Is it time to get rid all of my old cards
Yasser Amin
on May 6, 2010 at 7:21:58 pm
Hello
I have 3 station with 3 Declink Extreme PCI-X
each one Windows7 32 Bit + CS4 + 4G Ram
Now CS5 is native 64 bit and DeckLink_Windows_7.6.2 driver support CS5
I know that there is a problem with this cards and Windows 64 bit with 4G ram "not working at all"
and can't reduce my memory to 2G "have 2 X 2G ram"
Is the solution is to get rid of my 3 Declink Extreme PCI-X cards or I will get another solution from Decklink support guys
regards
nicky van der walt
Re: Is it time to get rid all of my old cards
on May 7, 2010 at 7:56:59 am
As far as I am aware the "4Gb RAM and card not working at all" in a 64 bit OS happens only with PCI versions of the cards.
Not sure about PCI-X versions of the cards though, as I only experienced this with PCI versions of older Decklink SP cards.
Yasser Amin
on May 7, 2010 at 8:30:59 pm
Hello nicky
thank you for replay
PCI-X cards working in PCI and PCI-X slot and have the same problem with 64bit windows "test it in Vista 64"
am looking now for a solution to reduce the memory from 4G to 3G by bios or by increase hardware reserved memory in windows 7
Does anyone has a suggestion
still waiting for Decklink support guys opinion
regards
Kristian Lam
on May 8, 2010 at 3:43:25 am
Hi Yasser,
Unfortunately, the PCI cards will not be able to support more than 4GB of RAM in a 64-bit operating system. This is not likely to change but all the current PCIe cards available now will work fine.
You could potentially setup a few cheaper logging or capture workstations with the older cards.
regards
Kristian Lam
Blackmagic Design
Yasser Amin
on May 11, 2010 at 2:40:51 pm
Hello Kristian
I think that you don't read my first post
I have 4G ram installed in my system and the card not working
any way I solved my problem and all cards working now and I will not rid of my cards, but sure I will add a new HD workstation
regards
