DVCProHD Sequence to HDCAM Master
Paul Toth
on May 6, 2010 at 3:52:09 pm
I am trying to output an hour long show that was edited in a DVCProHD 1080 sequence and export to HDCAM master via HD SDI, using the Decklink HD Extreme 3 card... can this be done? So far I have been unable to see any picture or sound on the HDCAM deck.
Paul
Kristian Lam
Re: DVCProHD Sequence to HDCAM Master
on May 8, 2010 at 3:39:27 am
Hi Paul,
More information would be good. Windows (Premiere Pro) or Mac? Either way, you will be able to do it on both platforms.
Firstly, verify that you have video/audio coming out to a monitor. If that's the case, then it's most likely a VTR setting. The HDCAM deck does multiple frame rates in HD so make sure it's set to the one you're outputting.
regards
Kristian Lam
Blackmagic Design
