Intensity driver request
Alan Okey
on Apr 14, 2010 at 5:08:47 pm
Here's something that would be a real benefit to the Intensity driver:
When using the Intensity's SD downconversion mode in Final Cut Pro, it would be great if Intensity would automatically shift 720x480 footage up or down one pixel to maintain proper field order when playing out NTSC (720x486) via the component analog outputs. AJA Kona cards do this, while Intensity does not.
Currently, the only way I can get a DV (720x480) resolution video to play back with the proper field order is to nest it in a 720x486 sequence. This is cumbersome and unnecessary.
Alan Okey
Re: Intensity driver request
on Apr 16, 2010 at 3:53:56 pm
Update:
I just updated to the latest driver and this issue has been corrected.
Alan Okey
on Apr 16, 2010 at 8:26:19 pm
Another update:
After a Pro App update and a restart, the field order on 720x480 sources is wrong again. Reinstalling the latest driver again didn't help.
Alan Okey
on Apr 24, 2010 at 12:55:59 am
Hopefully the final update:
After powering off the system, the field order has subsequently been correct for 720x480 material displayed using the 720x486 output setting, so apparently the required field shift is being applied.
