Intensity Pro
Jose Burgos
Intensity Pro
on Apr 2, 2010 at 5:52:00 pm
Is there a way to use the card for HMDI in and SD analog out in real-time? I can do HDMI to Analog Component at HD resolution works but I am trying to get it to output to SD resolution it any analog format.
Thanks in advance,
Jose Burgos
http://www.burgosfx.com
Kristian Lam
Re: Intensity Pro
on Apr 3, 2010 at 10:19:48 am
Hi
Not while you're capturing. But if you're playing back a HD clip, you can able down conversion in the Blackmagic preference pane to get SD output.
regards
Kristian Lam
Blackmagic Design
Jose Burgos
Re: Intensity Pro
on Apr 3, 2010 at 2:14:39 pm
Yeah on playback every possibility works but I was hoping for real time to use it as a scan converter for computer display in to SD out. I guess I can upgrade my TriCaster to an XD300 or purchase a scan converter if this is the way I need to go.
Was hoping one of you BMD gurus had a trick up your sleeve :)
Thank you and Take care,
Jose Burgos
