Will any cheapo 24" 1920x1080 monitor work well with the Ultrascope
Peter Corbett
on Mar 26, 2010 at 9:16:14 am
Just about to order a Dell monitor to go with my (also ordered) Ultrascope. Will the cheaper 6-bit 24" work just as well as the more expensive 8-bit high-end Dell 24"? I don't want to spend more than I have to but want the best picture quality for the price.
Cheers,
Peter
Peter Corbett
Powerhouse Productions
http://www.php.com.au
Peter Corbett
Re: Will any cheapo 24" 1920x1080 monitor work well with the Ultrascope
on Mar 26, 2010 at 10:51:13 am
Or will one of the 21" 1920x1080 monitors work just as well?
Peter Corbett
Margus Voll
on Mar 26, 2010 at 12:15:39 pm
Hi.
Look here:
http://www.blackmagic-design.com/press/detail.asp?pressID=181
So it should work fine.
Margus
http://iconstudios.eu
Kristian Lam
on Mar 27, 2010 at 8:34:48 am
This is correct. As long as your monitor supports 1920x1080 or 1920x1200, you can run all 6 displays. If your monitor has a minimum of 1280x800, you can run the 2-Up view.
regards
Kristian Lam
Blackmagic Design
