MediaExpress 2.03
Andreas Wideroe
MediaExpress 2.03
on Mar 15, 2010 at 8:24:10 am
Is finally out. It has 1280x800 screen size! Thank you Blackmagic - it's finally here! Hooray! :-)
http://www.decklink.com -> support -> software downloads
/Andreas
Iliya Gitlin
Re: MediaExpress 2.03
on Mar 15, 2010 at 10:57:43 am
Hi, how i can change quality for motion Jpeg avi - standart settings is very low quality - i need capture mjpeg quality equal to DV
Kristian Lam
on Mar 15, 2010 at 12:46:48 pm
Currently, the MPJEG quality settings cannot be changed. However, the quality should be very good. Maybe it's worth double checking to see if you have any other codec packs installed on your system. There's a chance the wrong codec is used due to a conflict.
regards
Kristian Lam
Blackmagic Design
Iliya Gitlin
on Mar 15, 2010 at 1:06:48 pm
i don't have installed any other codec or codecpack, quality is low - 30 min SD PAL video file size is 1.6Gb - it's very small for good quality in mjpeg
Margus Voll
on Mar 18, 2010 at 6:26:55 am
HI.
Then there is something really wrong. You should consider something like 2 times dv size for files.
Margus
http://iconstudios.eu
Iliya Gitlin
on Mar 29, 2010 at 10:46:34 am
When can we see support for DV format MEdiaExpress 2?
