Premiere HDV setting
Allby Corry
on Mar 12, 2010 at 1:23:20 pm
If I need to edit HDV 1440x1080 with Decklink exterme HD and Premiere CS4 in which configuration should open the project? Blackmagic's setting only show HD 1920x1080.
Thanks..
Callum McLay
Re: Premiere HDV setting
on Mar 14, 2010 at 10:50:46 pm
Hi Allby
When working with HDV video at 1440 x 1080, Premiere automatically scales this back up to 1920 x 1080 for playback. Therefore, you can choose a Blackmagic timeline at 1920 x 1080, and your footage will playback at 1920 x 1080 through the cards outputs.
Callum McLay
Technical Support Manager
Blackmagic Design EMEA
Allby Corry
on Mar 19, 2010 at 8:19:48 pm
Thank you Callum,
There is some loss of resolution in this scale?
Regards
Tracy Peterson
on Mar 20, 2010 at 7:20:29 am
Some, but that's more a matter of shooting on HDV vs a native 1920x1080 format.
Tracy Peterson
http://www.onetwomany.com
Allby Corry
on Mar 29, 2010 at 1:17:06 pm
Thank you Tracy,
And if I set the project to HDV - 1440x1080.
The Decklink HD support this resolution?
Regards.
Tracy Peterson
on Mar 29, 2010 at 4:49:01 pm
Again, you need to use a BMD setting. If they have it, it will work. If you can't find one that will play back in real time, you may have to render, but the short answer is YES. It isn't tied to the footage, it's tied to the settings file.
Tracy Peterson
Allby Corry
on Mar 31, 2010 at 12:40:46 pm
Hi Tracy,
Thank you again.
Corry
