Building capture graph for YUV -> DPX
Andreas Rettig
on Mar 12, 2010 at 11:32:14 am
A very technical question...
I'm trying to build a working Directshow capture graph to capture DPX files of a YUV-Decklink-Videosource.
The Decklink Still Sequence Sink seems to accept only RGB as input.
Now I can't find the right filter to convert between YUV and RGB which is accepted. The only one working is the "Blackmagic 10bit 4:4:4" Compressor which drops the performance too much.
The Blackmagic DMO should do it, but is not accepted.
Since MediaXpress 2 has that switch "Capture DPX from YUV sources", that should be possible with nice performance with the availabe filters. But I can't get the right graph...
Any suggestions?
Thanks in advance
© 2018 All Rights Reserved
