A little confusion over capture sizes 1888x1062 @ 29.95??
Navarro Parker
on Feb 15, 2010 at 3:25:00 pm
Recently did an all day on-location capture with a Decklink Studio card in a Mac Pro. Captured 1080i/59.94 (29.97) as ProRes 422 HQ and Uncompressed 8-bit via SDI from an EX1 cam.
I return to base to review the footage. And Quicktime Player is giving me weird pixel dimensions.
In Movie Inspector, I get this:
Format 1920x1080 (1888x1062)
FPS: 29.95
Normal size: 1888x1062
Current size: 1888x1062 (actual)
So what's this 1888x1062 business? Am I not recording at full 1920x1080 raster? I'm viewing this on a 30" screen, so the movie is at 100%. Final Cut and After Effects both report it as a 1920x1080/29.97 clip. So I'm very confused.
Kristian Lam
Re: A little confusion over capture sizes 1888x1062 @ 29.95??
on Feb 16, 2010 at 10:57:56 pm
This is the conform aperture setting in Quicktime. See this Apple technote:
http://support.apple.com/kb/TA24215?viewlocale=en_US
regards
Kristian Lam
Blackmagic Design
Navarro Parker
on Feb 17, 2010 at 9:48:47 am
This is the first I've ever heard of Quicktime conform aperture!
Wow, that Tech Note confused me even more. So Quicktime Player Pro is cropping and scaling my movie?! That doesn't sound good, does it?
I'm using QT Player Pro to convert my Uncompressed 8-bit to ProRes HQ. From your link, it sounds like I shouldn't unless I individually modify the aperture settings? Should I be using Compressor?
Kristian Lam
on Feb 19, 2010 at 4:17:06 am
[Navarro Parker] "Wow, that Tech Note confused me even more. So Quicktime Player Pro is cropping and scaling my movie?! That doesn't sound good, does it?
Not really. It's just a presentation mode. The file is untouched at all. You can change the settings back to "Classic" if you find any issues while re-compressing the clip in Quicktime.
regards
Kristian Lam
Blackmagic Design
Hope Holmesby
on May 9, 2013 at 4:04:30 pm
you can reset quicktime 10 to 'Classic'?
how?
or maybe you are talking about qt7?
thanks
__________________________________________________
Life is here to enjoy.
iMac 3.5 GHz Intel Core i7, 2TB; Mac OS 10.6.8, 16 GB RAM; 2 La Cie external HDs 1 TB each; After Effects CS5.5; Sound Track Pro 3.0.1; Final Cut Pro 7.0.3; Compressor 3.5.3
