Apple Color +Intensity Pro+HDMI+Plasma?
Sam Roberts
on Feb 11, 2010 at 2:16:53 am
Hi. I am looking for a low cost solution for grading with Apple Color in HD using an HDMI output to my Panasonic plasma monitor from an i/o card in the PCIe slot of my MacPro. Will the Blackmagic Intensity pro do the job?
I already have AJA's ioHD which will not output an HD signal from Color but does everything else i/o-wise.
Margus Voll
Re: Apple Color +Intensity Pro+HDMI+Plasma?
on Feb 12, 2010 at 10:39:59 am
Hi.
How you plan to calibrate your system so you get what is that you correct?
It seems to me bit tricky to grade wo sdi output.
Margus
http://iconstudios.eu
Sam Roberts
on Feb 13, 2010 at 12:53:45 pm
The Blackmagic will be an interim step until I have the budget for a high end SDI monitor. All my clients will watch my projects on TV anyway and I am not doing film out. The plasma has been lined up using a DVD made for that purpose and looks very good, surprisingly good actually. Are you using this card? How do you like it? The HDMI out quality is good?
Sam Roberts
on Feb 13, 2010 at 8:39:44 pm
Nobody using this card to output from Color?
