RED FCP7 Capture on MAC PRO with Blackmagic Decklink Extreme
Arnold Foote
on Jan 20, 2010 at 3:49:08 pm
Dear Friends,
I am screwed.
The RED drive we recorded to (3K - 48fps) won't mount on any computer but the footage is playable inside the camera. I am attempting to capture from the camera and I am not getting anywhere... no signal.
Please give me some guidance any time you can. In the mean time, I am going to the hardware store for rope.
Be back soon.
J
jj.foote@mac.com
jj.foote@mac.com
Arnold Foote
Re: RED FCP7 Capture on MAC PRO with Blackmagic Decklink Extreme
on Jan 20, 2010 at 5:20:34 pm
An update for you, I see signal on the broadcast monitor with the signal going through the card in the mac, but FCP says "No Input Signal"
How can that be?
Does anyone have a workaround?
jj.foote@mac.com
Margus Voll
on Jan 20, 2010 at 7:32:11 pm
Hi.
What input type do you have enabeled?
Eny support from RED?
Margus
http://iconstudios.eu
Arnold Foote
on Jan 20, 2010 at 7:35:06 pm
I have tried all output options from the RED.
Input using the HDSDI in to the Decklink extreme... far right of the three connectors at the back of the computer.
jj.foote@mac.com
Tracy Peterson
on Jan 21, 2010 at 10:32:35 am
When using a DeckLink for capture you need to set FCP up with a "Easy Setting" that works for your camera output signal. Basically whatever is hooked up to that input HD-SDI on the decklink.
After a little research, I have this advice: check to make sure HD-SDI output is enabled in the menu as only one output is enabled at a time and you'll need to set FCP up on a 720p59.94 setting. That is apparently the only signal that the RED will output.
You may want to hook up a monitor to the HD-SDI that can do that setting on the pass through to make sure signal there.
Good luck.
Tracy Peterson
http://www.onetwomany.com
