Intensity Pro and Flash Media Encoder 3.0
Marek Tamm
on Jan 5, 2010 at 11:14:54 am
I cannot make Intensity Pro work with Flash Media Encoder 3.0 in higher than 720x486 resolution. It just won't give such optionOlder FME 2.5 works with 1920x1080, but has problems with frame rate.
Has anyone been able to live stream higher resolutions with Intensity Pro? And with what software?
MT
Tracy Peterson
Re: Intensity Pro and Flash Media Encoder 3.0
on Jan 6, 2010 at 8:31:19 pm
Thanks for pointing this out, I just grabbed 3.0 and on my DeckLink Extreme HD it is doing the same hustle for the input size. I don't know if it is a bug with Adobe or with BlackMagic Drivers.
Tracy Peterson
http://www.onetwomany.com
Kevin Lighty
on Jan 11, 2010 at 3:22:54 am
I am in the EXACT same boat.
We bought the card so we can stream our newscasts online. Since we are outputting HD the HDMI was neccessary.
We used to use Flash Media Encoder, but have the same problem you mentioned.
Can anyone help here? Or suggest a different program to use that can capture both video and audio and then stream it?
Kevin
Robby Dickens
on Jan 21, 2010 at 11:25:06 pm
i am using an intensity pro with flash media live encoder 3. i had the same problem with the input size and not being supported. so i installed vh multicam studio. When you open fmle it will open the multicam program. Go to file add the camera as your decklink card, set the resolution and frame rate. Then you will have alot more input options in fmle. I have since ran into a problem though. My cpu is maxing out now. So i am dropping alot of internal frames. Maybe someone else will have more luck with this setup.
Sean McPartlin
on May 5, 2010 at 2:33:40 pm
So with the new update for FMLE 3.1 released in May 2010 you can now capture from 1920x1080 with the Black Magic Intensity Card.
That's a good thing. But I am getting FMLE 3.1 crashing in x64 windows 7 when I try and encode from source....
Maybe it's my settings... I actually want to stream 1920 x 1080 with Flash
Anyone else get that to work... please share the magic...
I have loads of bandwidth...
Tracy Peterson
on May 6, 2010 at 12:35:34 am
Have you tried the shiny new 7.6.2 driver set?
Tracy Peterson
Sean McPartlin
on May 6, 2010 at 1:32:04 am
I don't think so... Got a link to it?
I did get it to capture from whatever I'm running with FMLE 3.1 but it crashes with an unknown error after a short period of time..
But I do see video in the preview now and 3.0 didn't do that...
Tracy Peterson
on May 6, 2010 at 2:41:55 am
It's on the BMD site.
http://www.blackmagic-design.com/support
Tracy Peterson
