Blackmagic 7.4 Premiere 4.2 - Print to tape, out of sync.
Eyal Shilon
on Dec 7, 2009 at 1:37:38 am
Hi
Windows XP 32bit
Premiere CS4 4.2
DeckLink SD Extreme PCI (Old model)
Driver 7.4
Premiere, Blackmagic PAL Time-Line Preset,
SDI A/V OUT in to BETA SX:
Play Back & Editing OK
Print to Tape:
Audio out of sync 1/2 second
Started in Premiere 4.2 +Blackmagic 7.4
Jeff Kosmicki
Re: Blackmagic 7.4 Premiere 4.2 - Print to tape, out of sync.
on Dec 9, 2009 at 10:24:43 pm
I have the same problem, audio is early by 7 frames when exporting to tape. Also using Premiere 4.2 and Decklink 7.4
Vista 64
CS4 4.2
Decklink Studio Pro 7.4
Jeff Kosmicki
http://www.toyraygun.net
Claus-Peter Wolf
on Dec 10, 2009 at 10:22:29 am
jepp, also same problem...for the moment is decklink
not really usably..
i have some more problems:
-when rendering the green bar over the clip dissapears..
i have to zoom in or out in the timeline to see if
the clip is rendered!
-Next problem: when i dublicate a timeline to make changes
i have to render all the clips again in the new timeline.
(in the old timeline they stay rendered!!!)
-when i edit dv and apply a effect, i have after i rendered the
clip a "line jump"!!! (Very old problem, posted many times!!!)
- When i open a project, many times premiere has to (i don´t
know how it is in englich!) "apply" the audio for all clips
again (right bottom corner in premiere)
- Also when i reopen a project Premiere has to render some effects again!!!
- The serial device Control doesn´t work!!! Some "com" Problem
I have to use Decklink Device control, and this one is long not so good as serial device Control!!!!
- When i capture in mjep the picture quality is really bad!!
- DVPro capture has drop frames!!!
- When i render clips, they change a liitle bit of croma-level!
Really really bad 7.4 driver (many of those problems i had also with 7.2 and 7.0 driver)
I tried 7.4 with Premiere Pro 4.2 in Win XP and Windows vista and Windows 7... on different Mainboards with 4 different Decklink Cards and different grafik cards...difeerent RAM and even with Sata Controlle or without Sata Controller different Hard disks!!!! In any configuartion i had the same problems!!!!
So please Decklink guys, don´t tell you never heard about
some of this problems!!!
And please don´t ask me about my configuration (it alway the
same question) i use recommanded boards...latest driver and so on.
So just work a little less with your davinci and make decklink
now work!!!!
For the moment is stepped back to PPro 2 and 6.4 drivers.
This one work okay (exept the DV Problem!)
I am really tired about testing your drivers...
Greating from Cologne
Claus-Peter Wolf
Callum McLay
on Dec 17, 2009 at 2:00:45 pm
Hi Guys
I am from the European support office for Blackmagic Design.
These aren't problems that we have had reported to us so far, however I would be happy to look into them for you, and ensure that any problems that do exist are addressed.
Please feel free to contact me directly at:
support-emea@blackmagic-design.com
and we can begin looking into the problems you are experiencing, and see if we can help in any way.
Callum McLay
Technical Support Manager
Blackmagic Design EMEA
Tony Partamian
on Dec 20, 2009 at 9:46:37 pm
I also emailed Decklink support about the MJPEG quality issue and they replied a month later that it's a known problem and that they are investigating the issue.
I wonder how the European support knows nothing about it.
Callum McLay
on Dec 20, 2009 at 11:33:01 pm
Hey Tony
We've actually been working through the problems mentioned in this thread and we are still running through them. I didn't spot the MJPEG thing on first glance, that's my bad, but we are aware of this particular problem, as are our engineering team.
As an update for you guys, the issues with laying off to tape being out of sync has since be raised to our development team, and they are looking into it right now. I know a couple of people have contacted us directly after my post, and so we will also be looking into possible work arounds in the mean time.
We are still running through Claus-peter's issues, and some of these appear to be the way Premiere works (ie having to re-render effects on a sequence after duplication), and some of them are not the way it is supposed to function (ie when using BMD timelines, you are only supposed to use the Decklink serial control, our driver is not really designed to use the system serial ports)
Callum McLay
Callum McLay
on Dec 23, 2009 at 8:13:57 pm
Hey Guys
Today we have posted new drivers for our capture cards, Decklink 7.5. These are available from the downloads section of our website here:
http://www.blackmagic-design.com/support/software/
So far, we have not seen the audio sync problem mentioned above with these drivers, so anyone experiencing this problem should update to v7.5. If you experience any problems, or need further assistance please get back to me either here, or at our support address!
Have a very Merry Christmas guys!
Callum McLay
Jeff Kosmicki
on Dec 28, 2009 at 5:14:49 pm
The 7.5 drivers fixed my out of sync issues when exporting to tape.
Jeff Kosmicki
