Intensity Pro usb port
Camilo Candia
on Nov 18, 2009 at 8:11:16 pm
Hi.
The Intensity Pro on the back comes with a USB port.
That serves this port usb????...
Thanks...
Camilo..
Brian Louis
Re: Intensity Pro usb port
on Nov 19, 2009 at 6:16:42 am
Those are HDMI ports
Camilo Candia
on Nov 19, 2009 at 1:27:30 pm
If, I know the hdmi ports.
The Intensity Pro has a USB port that is inside the pc, Installed in the electrical circuit card.
For serving?????...
Thanks...
Brian Louis
on Nov 19, 2009 at 10:25:03 pm
When you said the back I thought you were refering to the I/O ports, the small port is probably a test port, someone from BM probably could comment.
Camilo Candia
on Nov 20, 2009 at 1:19:18 pm
Brian thanks for your time..
Joshua Helling
on Nov 24, 2009 at 1:21:05 am
This port is for internal programming and will not be used by the customer in most cases. This is how we program the board at the factory. It will not function when the board is installed in the computer.
Hope this clarifies.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
